Old 02-23-2009, 06:51 PM   #1
pig rig
pig rig's Avatar
Question 1/2T 3/4T and 1T swapping
I see this question asked a lot on truck boards.
"are the 1T front suspension the same as the 1/2T or 3/4T same as the 1T?"
I'm not a guru but I have played with interchanging the 73-87 chev's front ends a little bit, so I hope I can help out those that don't have the parts resorce to figure out what works and dosn't.
ok....... follow along
3/4T spindles are different then the 1T srw and the differance is how the brake calipper mounts
but 1T spindles are the same for srw and drw trucks
3/4T rotors are not the same as 1T swr rotors and drw rotors are different then both
1T srw and 1T drw calippers are the same and 3/4T is different
woo....
ok, balljonts are the same for 3/4T as for 1T srw and drw
and arms are the same for 3/4T and 1T
and none of this stuff interchanges with a 1/2T
but the 1/2T crossmember is the same as the 1T and 3/4T so with 1/2T A arms and spindles you can swap your 3/4T &1T to a 1/2T
now! with that saidI know the 4wd interchange question is going to come up. and the only thing I know about 4wds is you can part them out to fat'n up your wallet. and thats all I want to know!
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-23-2009, 10:37 PM   #2
b454rat
Re: 1/2T 3/4T and 1T swapping
Can't comment on 2wds, I don't mess with them anymore.
As for 4wd, just aboot everything is interchangable, depending of course....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 02-23-2009, 11:02 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Thanks for the info Pig Rig.
Have you ever used ECE's "3/4 ton to 1/2 ton conversion" spindles to put 1/2 ton brakes on a crew cab? These should allow you to keep all of your 3/4 ton or 1 ton a-arms, ball joints, and tie rod ends. I just don't know of anyone that has tried it. I may have to be the first with my '89 srw 1 ton crew cab.
Keith
Convert to disc brakes.
Old 02-24-2009, 10:38 AM   #4
Storm Chaser
Storm Chaser's Avatar
Pardon me for asking... but why would you want to put less heavier duty brakes on than what it came with, especially on a big ole crew? I'm not being a smartazz, just trying to learn something, that's all.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-24-2009, 10:56 AM   #5
lolife99
lolife99's Avatar
I'm building a 1/2 ton shortbed crew cab.
Keith
Old 02-25-2009, 02:50 AM   #6
pig rig
pig rig's Avatar
lolife99 I've never looked into the ece set up but if you have a bearings dist. around your area, you could do a little research and save your self some big money I bet
the chev 1/2T bearing and race is pertty comen set in the industral setting
