Grandpa in the rustmobile...
disc brake/drop spindle kit..all a direct bolt on?
Looking at buying front disc brakes and drop spindle kit from a fellow member....he wants 500$+shipping....is this a fair price, or should i keep shopping? Is everything there i need? or will i have to get new balljoints, tie rod ends, tie rods, or anything else?? really like to convert my drums to disc and lower a bit too while im at it...not really sure if its worth his asking price of 500. i hope this is not against the rules for me asking this type of ? if its illegal mod. delete this or i will.....
thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
resident oilfield trash
Re: disc brake/drop spindle kit..all a direct bolt on?
I paid like 300 shipped for my spindles new. Got my rotors from a salvage yard for 20 dollars. Calipers are 13 dollars a piece new. Hoses are like 20 dollars each side. So I have 353 in my whole setup. Direct bolt one to current hard ware. so its really up to you I guess.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Let me know if you want a parts list
yeah interested in a parts list!!
so u bought drop spindles new, rotors from what year? thanks!!
Magauphys 2.5 drop spindles 250 plus shipping from Godfather customs
My spindles are for 1 1/4 rotors. My rotors came off of a 92 Chevy Pickup. Cost me 20 at a junk yard Caliper for a 73 to 87 Chevy pickup 13 each from Auto zone Brake hoses from 71 72 Chevrolet pickup 20 each side So to me 500 sounds a little high. But if you buy new rotors they are like 100 each
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 02-23-2009 at 08:25 PM. |
thats everything you'll need?
thanks alot jbristo67 ima work on that!! much appreciated!
oh gotta nother ?
what year of drop spindles do i order? will any brand of 2.5" drop spindles work also? thanks
If you have a 68 order for a 68. McGauphys Are some of the best spindles you are going to be able to buy for your truck. Here is a link http://www.gcustoms.com/product_info...rop%20Spindles Here is the one for 1 inch rotors which are the ones that are generally on 73 to 87 pick ups http://www.gcustoms.com/product_info...rop%20Spindles 1 1/4 rotors are generally on 88 to 98 pickups
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 02-24-2009 at 01:35 AM. |
So I'm also in the "drum to disc" conversion. I have a 68, 6-lug drums. I jus bought a set of spindles for $65 (u can see a pic of them on craigslist/Bakersfield, CA). Exactly what else do I need? Also I found a complete front end(5 bolt) off of a 72 for $250, which way is easier? Not cheaper, easier! Should I piece together the parts or buy the front end?
![]() Join Date: May 2007
Either way check ball joints and tie rods for wear and upper and lower cross arm shafts but imo change the whole front end. That way you can take your time, then change it out one saturday.
so if i get 1" rotors from a 73-87 i need to get the 73-87 calipers?
and just check the balljoints tierod ends? thanks
#12 | |
Under Construction
We did the complete '72 front member swap and rear end swap on my sons '67. we also installed 2.5 drop spindles while we had the crossmember apart for painting etc. you can see pics in our build thread . As far as being easier it depends on what stage you at with your truck. if the motor/trans is installed it adds some complexity to switching out the crossmember as a complete unit, but could replace the balljoints on your current UCA /LCA to the 72 balljoints and use the 72 parts (spindle out, and all linkage)from the other crossmember to switch over
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#13 |
if i get 88-97 rotors then i need that year of calipers too, correct,
or if i get 73-87 rotors, then i need 73-87 calipers too right list to get 73-87 calipers/rotors 71-72 brake lines 1968 2.5" drop spindles
#14 |
BOHICA
JBRISTO
So there were no issues using new drop spindles with 92 rotors, any difference with the bearings?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
#15 | |
#16 |
None what so ever I even bought new 92 bearings. Perfect fit
#17 |
No you have to run 73 to 87 Calipers they are the only ones that will bolt up to your spindles. Best thing to do if you are going to run 88 to 98 rotors is to get Calipers from a 89 sub (still square body) All subs had the hd 1 1/4 brakes so you cant go wrong there.
#18 |
Jbristo: I'm not too smart! If I go to the bone yard, what years can I get the rotors off of? I can do like you did and jus buy new calipers. Also, what do I have to do to the master cylinder and proportion valve?
#19 |
Auto Zone 100 dollars master and booster. Just ask for your year. You can use 73-98 rotors. 73-87 pickups are mostly 1 inch rotors but there were some with hd brakes that were 1 1/4. 88-98 are all 1 1/4 rotors. You can use either one. My advice would be to go to a bone yard, find the best rotors you can. Measure them if they are on a 73-87 to see if they are 1 or 1 1/4 or if its 88-98 you know its 1 1/4. Then order your spindles and tell the guy you have either 1 or 1 1/4
#20 |
ooookay
so leme get this straight 88-98 rotors 73-87 calipers (new is cheaper??) drop spindles (what year, disk brake years 71-72, or my trucks year, 1968???????) brake lines from 71-72? wata bout master cyclender and wat row said, proportioning valve? i dumb i need a parts list lol thanks and sorry
#21 | |
Yes if you end up with 1 inch rotors then you need calipers off of a 73 to 87. If you get 1 1/4 I would get calipers of a 89 90 sub just called they are 11.99 each
#22 |
Dont worry about it man. When I first started asking these questions I wasnt any better
#23 |
wait a sec. sombody just said i gotta get 73-87 calipers ONLY cause the 88-98 wont fit my spindles i'll be buying
and which spindles do i order??????????!!!!!!!!!!!!!!? thanks lol tryin to get a good solid idea of wat i need to order lol
#24 |
okay so master cyclinder booster buy new from autozone, roughtly 100$
rotors, do i want 1.25" or 1" calipers, what should i expect to pay for a good used set of these, wat makes them good shape? use info up there^^ for sizing calipers, do i buy new or used, i thought somebody said i could get em new for like 20 per side but i may be wrong...use info up^^ there for sizing drop spindles, im still unsure of, do i get the spindles for the drum break years (67-70?) or disc years (71-72) sorry im sure im pissin somebody off askin all these ?'s but yall're the only ones i can ask lol my bad for the ? hey gotta learn somehow lol thansk!
