12-13-2002, 09:49 PM | #1 |
Fords Worst Nightmare
brake question
ok heres the thing, i have to push the brake pedel all the way to the floor to get it to slow down, feels kinda like i have no brake pressure or something, and when i do push the brake pedel it always pulls to the right, so what could be the problem(s).
My 69Chevy C/10 Yee Boo |
12-13-2002, 10:57 PM | #2 |
Cantankerous Geezer
Time to pull the brake drums and do an inspection. You either have a drake on the right grabbing or a brake on the left not grabbing. And you will most likely find a wheel cylinder leaking, too.
Fred There is no such thing as too much cam...just not enough engine. |
12-13-2002, 11:21 PM | #3 |
I would look for a leaky wheel cylinder. Check the master cylinder and see if one of the resevoirs . If rear is low check your rear wheels for the leak or vice versa.
If it's not low on fluid, I would say your shoes are way out of adjustment, but since mine did the same thing, I'll almost bet you lost a wheel cylinderthough
12-14-2002, 12:23 AM | #4 |
Registered Abuser
Also if it is a wheel cylinder you need to redo both sides at the same time,and it's a lot cheaper to buy a kit that you can rebuild the cylinder's with than it is to buy a new cylinder.
And be sure and bleed the brakes when your done. |
12-14-2002, 12:35 AM | #5 |
check the price for a new one compared to the kit you might find for a few doolars more you can have a whole new wheel cylinder and not have to hone it or anything. around town here i think it was between 10 and 15 for a new one rather than a kit at 7 or 8.
69 chevy short wide box project 70 GMC jimmy project |
12-15-2002, 12:42 AM | #6 |
it was none of the above, come to find out when i pulled the wheel the brake drum broke in half(no pics sorry) and plus both brake pads on both sides were bad but after i put a new drum on it worked finer than a frog hair.
12-15-2002, 12:54 AM | #7 |
a guy at work says that when you ask him hows he doin,finer than frog hair
12-15-2002, 12:58 AM | #8 |
Pronounced "Pew-al-up"
Thats gotta be downright fine!!!!!!!!!
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
12-15-2002, 12:58 AM | #9 |
my dad says finer than a frog hair slipt 4 ways
12-15-2002, 09:15 AM | #10 |
Fabricate till you "puke"
Yup, finer than frog hair split 4 ways
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
