02-23-2009, 10:00 PM | #1 |
Junior Member
Anyone run a side-exit exhaust with a step side bed?
I've seen a handful of trucks with a side-exit exhaust run under the steps exiting right before the rear wheel. Is anyone on here doing the same? I'm interested in clearance issues with the rear leafs or if anyone has run one with a 4-link and how it all fit together.
-Andy |
02-23-2009, 11:00 PM | #2 | |
Re: Anyone run a side-exit exhaust with a step side bed?
I used stainless Z-28 rectangle exhaust tips and I notched the running boards so that I could tuck the tip up tight so the tip follows the same thickness as the running board. Since mine is only a few inches from the running boards touching in the back when aired out I could not just hang the tips below the running boards. Marc |
02-23-2009, 11:50 PM | #3 | |
02-24-2009, 02:21 AM | #4 | |
02-24-2009, 09:02 AM | #5 | |
My truck is blown apart at the moment getting ready for paint. I could only take a picture of the notch in the running board with the exhaust tip temperarily set in place. Thanks Marc |
02-24-2009, 09:54 AM | #6 |
Check your local laws for this.. I know here in GA we have a law requiring the exhaust to exit beyond the rear axle for passenger vehicles..
Or maybe it is a local ordinance.. With that said I am going to tuck my mufflers up within the lines of the frame rails and then have them turn down behind the rear fender at the rear... Going to be tight with me planning on laying frame but I think I can work that out..
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
02-24-2009, 12:58 PM | #7 |
My mechanic told me I can run my exhaust under my rear axle...does that make sense? Doesn't really to me but I'll wait and see.
02-24-2009, 02:00 PM | #8 | |
Junior Member
Anyone have any pics? |
02-24-2009, 04:22 PM | #9 | |
Because I am using a g-body frame. My frame and gas tank coupled with the fact that I am using air ride limits me from going all of the way out the back or side. My exhaust system will be in 2.5" SS. I went with SS flowmaster I think 40 series. They are not suppose to be very loud. I have some of the pipe bent but I need to have some help where it drops down from my headers. Marc Last edited by youngrodder; 02-24-2009 at 04:23 PM. |
02-24-2009, 07:35 PM | #10 |
Junior Member
Its a little hard for me to do any more than just eyeball stuff since I ripped off the bed and rear leafs on my truck too but it seems that the tips should exit somewhere right around the place where the front spring hanger is located on the stock suspension. That's not far off the spot I'd likely be mounting the front of a 4 link setup so it looks like I'll probably be clear for running it out that way and not hanging up on the suspension. The stock '59 frame itself seems to offer plenty of room to fit the exhaust tubing in between the bottom of the rocker and step and the underside of the frame.
02-24-2009, 07:42 PM | #11 |
You can, but I have always ran mine over the rear or dumped it in front of the axle. I don't like stuff hanging below the axles or even frame rails for that matter. Sounds like the mechanic doesn't want to mess with it.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-24-2009, 08:56 PM | #12 |
02-25-2009, 01:20 PM | #13 |
It was his suggestion as we talked about alternatives to running side exhaust or cutting a hole in the bed. I guess he's done this before with some lowrider cars and his own merc lead sled.
02-25-2009, 01:34 PM | #14 | |
polishing a turd
i had a problem getting my mustang inspected with dumps in front of the axle, because it didn't go to the perimeter for the car away from the passenger compartment, that is probably what you are talking about, or something similar
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
