Not a bad nut after all..
Picture of radiator supported mounted windshield washer jug
I'm looking for a few good pictures of factory radiator support mounted windshield washer jug and bracket. I think I've seen this on the driver's side of a '67?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
Re: Picture of radiator supported mounted windshield washer jug
It's on the drivers side of my 68---right next to the radiator.
On mine I'm using it for my overflow until I find out where the overflow jug should go. you might see it in my picturetrail below: http://www.picturetrail.com/100chevy Mike. ![]() ![]() |
Old member
I have this one for sale in the parts board. It's a factory bracket and jug off my 71. $25.00 shipped. It mounts wherever you want it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-07-2009 at 05:45 PM. |
#4 | |
its all about the +6 inches
blood type; Retumbo
I have a 1 gallon tank with built in pump from a motorhome mounted on a hand made bracket. next on the list is wet arm conversion.
Old member
This is what I have installed now. I got tired of the factory pump not working so I installed this unit. It has been on the truck for 8 years now and is not failed me yet. It works off the factory switch also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I have seen them on the core support, but I think it was an AC truck...and perhaps it was a custom camper with an aux battery. Now that I think about it I cannot picture the correct designated area where it was located on that rig as the battery would take up the space where I assumed it would go.
Future TOTM Winner
As it turns out, I happened to take a picture of mine in my parts truck this afternoon. I might have more pics somewhere. By the way, its a 69 with a 350 and A/C.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Is it difficult to remove the jug (it looks like it is under the top lip of the radiator support)?
#10 | |
This is the closest picture I could find. I'd like to see how it mounts to the radiator support, though.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer Last edited by badpeanut; 02-24-2009 at 12:39 AM. |
mines on the left side of my 68
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
I found a few good pictures from the electrical section of the board:
