Need the foam seal for heater defrost vent
Can anyone tell me where to get the foam that sticks to the door that swiches the hot air from the floor to the defrost. The original foam that sealed that door has fallen off like a prom dress. Thank you for all the help. 1972 chevy pickup
Old member
Re: Need the foam seal for heater defrost vent
Are you talking about the rubber part on the rod inside the devertor box? If so I have tried putting glue and everything else in there and I ended up buying a new box.
The rod is incapuslated into the rubber and after time it works loose. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
