Old 02-24-2009, 01:57 AM   #1
Choptop32
Question 64 1ton to 5 lug conversion?
Looking at a 1 ton panel, but want to run 5 lug wheels.
what is required to change it over?
Choptop32 is offline   Reply With Quote
Old 02-24-2009, 09:13 AM   #2
LILRED66
LILRED66's Avatar
Re: 64 1ton to 5 lug conversion?
There are unlimited choices of eight lug wheels, so the money you would save on doing the conversion can be spent on the wheels and tires of your choice.
LILRED66 is offline   Reply With Quote
Old 02-24-2009, 11:39 AM   #3
Choptop32
Actually i want to use these...
http://www.radirwheels.com/tririb.htm
and they only come in 5 lug.
Old 02-24-2009, 01:58 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
not 100% positive, but I think it would be the same as converting a 64 -6 1/2 ton
just use a 73-87 front suspension, and rear axle, depending on the rear springs, leaf or coil change to a lighter duty or lowering spring.
Old 02-24-2009, 02:04 PM   #5
Choptop32
hmmm... will look into it.
danke mucho.
Old 02-25-2009, 01:19 AM   #6
Captainfab
60-66 Nut
Just convert it to a '73-'87 C10 suspension. If you can find a complete parts truck (suspension wise), that would make it easier. Of course if you plan to upgrade the drivetrain as well, finding a truck with that would be good as well.
