71 keeps dying and not starting...
I have been reading past posts for weeks now and slowly replacing parts and doing housekeeping under the hood, but I still have the same problems that have been bothering me for a few weeks.
So the truck just dies while driving, probably every other day. I drive to and from school which are 8 and 17 miles apart (two campuses) and it doesn't matter where (freeway, side streets, slow construction areas) or when, it just dies. I can try to restart it- sometimes the battery acts fully charged, cranks and I have to give it FULL throttle, fires up- and sometimes the battery acts drained, and If I wait a while (30-40 min.) there's a 50-50 chance that it will start up, FULL throttle again. I have replaced the fuel pump, cleaned the tank completely, cleaned the fuel lines, replaced the alternator and the starter solenoid and kicked the truck very hard. The battery tested good for autozone. Probably not good, but I pulled the POS off the battery while running (the last time I had to jump it and drive it home) and the engine died. Right now I have a trickle charger on it and will take it off first ting in the morning. It's got a 350 small block, and for the most part stock all around. I am stuck. I have done hours of research on the forums, hours of busting my knuckles under the hood, and still have to keep my bicycle in the bed just in case. Any help would be very appreciated. Last edited by 71wongbed; 02-24-2009 at 03:26 AM. |
My Mistress the Sea
Re: 71 keeps dying and not starting...
Probably multiple problems.
Bad battery power could be charging circuit. New alternator could be bad. Could also be a bad connection either end of the circuit causing intermittent power loss. Starting at full throttle could be flooding. More air with the carb open all the way. I've had vapor lock act like that, but it shouldn't affect the charging circuit. What happens when it dies?
,,,they'd look alot better as beer cans... '71 K20 350/350 Rusty but trusty... gone '70 C20... gone '88 K1500... gone '90 C1500... gone '91 C2500... gone '95 C3500 6.5L Dually love this one!... |
its all about the +6 inches
welcome to the forums.
You said when you unplug the bettery, the engine dies. While not a good way to test it, that says you are not charging. Have you replaced the external regulator? |
![]() Join Date: Aug 2006
When I bought my truck, the PO said mine did the same thing. I found a wire that was grounding on the exhaust when when it moved due to driving the truck. That wire cost him about $1k and the shop never found it. Check for that and do a voltage check at the battery, alt and regulator to check condition of charging circuit. You should see about 13-14vdc. Do this check again with all of your accessories on also. You may have a dead short somewhere in these circuits. Your starter could also be the cause of this, check the wiring to it and its general condition.
Good luck. |
have you changed the fuel filter IN the carb? if 4brl quadrajet theres a filter in the carb where the fuel line goes in ,large nut on the carb needs to b unscrewed to get it out
Active Member
![]() Join Date: Jul 2007
Definitely sounds like what's been mentioned above -charging problem and maybe even a flooding problem.
I'd buy a small meter (less then $20) set it on the VDC scale at 15VDC or higher and while running put pos lead on the + and neg lead on the - lead. (I mention this in case there are others that are not familiar with testing a battery). It should read as mentioned above. A fully charged battery will run your truck or car for quite some distance before dying. I once drove a small 76 datsun almost 100 miles with a fully charged battery before it died. Last edited by 68gmsee; 02-24-2009 at 09:52 AM. |
Thanks everybody.
I changed the ext regulator about two years ago. I guess I ought to for the money. When it dies, it just dies, no stumble, no warning- similar to how it died when i pulled the POS lead on the battery. Sounds like I've got a grounding issue, whether it be a short, not a good ground, or both. I've got a digital meter and as soon as I get home I'll check the voltage all around (the battery will be charged, so I can fire it up and diag...) So, if the battery is not being charged, the truck is running off the battery, thereby depleting it more and more as I drive? makes sense I didn't know there was a filter in the carb! Could it be the terminal ends that connect to the battery? the POS is kinda eaten away, but looks like it gets a good connection. I'm going to mess with it a bit, thanks for the help everybody! |
Active Member
"Could it be the terminal ends that connect to the battery? the POS is kinda eaten away, but looks like it gets a good connection."
Most definitely. The ends get corroded internally and lose connection. I had them do it on another vehicle. The reason we didn't mention the cable/ground possibility was the you are able to start it after you charge it or wait 30 minutes or so. Wet cell batteries will recharge themselves to a certain point by the chemical reaction of the acid. Also, there is a small filter inside the carb fuel pump inlet. Remove the large nut and pull it out and you should see the filter. Let us know what you find. Last edited by 68gmsee; 02-24-2009 at 06:25 PM. |
Welcome to the madness.
I think I have had all of the same problems you are facing. Check your fuel sending unit, they plug up over the years and starve the motor for fuel. Check the carb filter and also check for any inline fuel filters. Definately check or change your voltage regulator. Mine when bad, and even the electrical shop missed that one. If you haven't done so, change your battery cables. They will corrode under the vinyl plastic cover. You can't see it, but it really messes up your electronics. Check your fuel line going to the fuel pump and from the fuel pump to the carb. Some of the new fuel additive really mess up the rubber fuel lines, especially ethenol. Check your altenator, make sure it is still putting out the correct amps. I had the family Nissan Pickup die on me once. The tow truck guy gave me a jump, it started fine, he pulled off the pos. cable and said, "your altenator is fine". I got fifty yards down the road and it dies again. He just pushed me to the nearest off ramp with a garage. Come to find the altenator was toast. The pulling off the pos cable from the battery was a way to check if a Generator was charging, not an altenator. Get yourself some starter fluid spray can. When it won't start, squirt some into the carb. If it starts right up, you have a fuel delivery problem. At this point, if you have checked everything else and it is ok.. you might have a weak fuel pump. The last thing I can think of, check the wires on your coil, (pos, neg). Are they making good contact? Oh yeah, one last one. I had a vehicle die on me, I could not figure out what had gone wrong. Turned out the battery ground cable, wasn't getting a good ground. Once I was able to get it grounded, it ran like a champ. Good luck and post when you get it fixed.
'72 GMC custom camper 350/350 |
Got It!!!
So, I got out my meter and started checking. I found with the neg terminal disconnected, there was a 5 volt charge between the neg cable and neg post. So, I started hunting, disconnecting everything I could think of. Get this, when I disconnected the POS cable off the battery (I was getting frustrated, just wanted to see 0 any way possible) there was still a 5 volt draw! That's when I decided I was just going to rip out the battery and throw it through the windshield. As I disconnected the steel strap the PO made to secure the battery, I noticed just how much corrosion had built up between the plastic top of the battery and the steel strap- I checked it with the meter- It was pulling 5 volts! The steel strap securing the battery in place was draining it! I was elated and absolutely pissed at the same time. Needless to say, I cleaned it up REALLY good, wrapped it with about 19 layers of electrical tape, secured it back and re-tested it and it was now 0, so I put everything back in place, buttoned it up, started it and re-metered it and counted the volts as they ticked up and up while the motor was running. I did replace the battery cable ends also, by the way. What a relief! Never could have seen this one coming... I REALLY appreciate the help and suggestions everybody. I look forward to chatting with you all in the future! Reuben Last edited by 71wongbed; 02-25-2009 at 02:15 AM. |
