1970 Daily Driver
Son's PowerWheels Needs Reverse
I got my son a small power wheels last year that has already clocked many hours. He is now to the age where he can steer a bit and understand where he wants to go. It was a used Power wheels and I had to wire it to accept an after market battery. It now has two spade connectors to connect to the battery. Yesterday I accidently revered the polls and it was going back wards when engaged. That got me thinking about installing a toggle switch for switching to reverse when needed. If I had a 6 pole toggle would that be possible? So my question is how would I go about wiring this setup?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 02-24-2009 at 02:25 PM. |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Son's PowerWheels Needs Reverse
Use a DPDT(double pole double throw) switch wired like this.
1970 Daily Driver
Thanks Bud!!! Check your User Cp for rep points. let me know if it adds any points to your total rep score number.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Grandpa in the rustmobile...
haha wow lol never knew that lol sweet reverse on a powerwheels lol..take chop the body make a 67-72 body for it lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
~Rest In Peace~
where is the little guys helmet ? kick up the voltage too watch him rip it up
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 02-24-2009 at 11:18 PM. |
#6 | |
You could use a single throw, not sure how hard to find and it would eliminate the middle "off" position, so it is either in fwd or rev. |
will also need a very heavy switch to carry the amperage dont know how much that powerweel pulls but I bet it is moor than a light duty switch can handle. you would not want to get the little guy burned just my thought.
I think they have 30amp fuses. I googled this everything your should need.
http://www.mendingshed.com/powwheelswit.html |
1970 Daily Driver
Thanks guys. Last night I got it all wired up and it works great. I took him out on it tonight and he was actual getting the hang of using it to back away from obstructions. It is 6volt and I read somewhere that power wheels use the same motor for there 12volt applications as they do for for their 6volts. So I threw my 14.6 drill battery on her and man did she fly. He made a run up and back on our street that I had to fast walk to keep up. I put the 6 Volt back in and it will stay as I don't want to burn up the motor. The motor looks like a cordless drill motor, makes me wonder about retro fitting a drill motor in it when he gets a little older.
I put a 2" chrome exhaust tip coming out the back, two dummy spark plugs and wires, a fake NOS bottle, a real GM lap belt, Boe tie emblem on the front, a windshield wiper nob on the dash as well as a fake lighter nob, cut in a Chevy clock in the dash, reverse toggle,and other little details. It has been a lot of fun to work on with him.
Enjoy while their little, The projects get bigger and more expensive.LOL
Hollister, CA.
![]() Join Date: Sep 2006
My son has a pumped up powerwheels too....his is a 24Volt Big-Foot.....
He's gonna be the next drifting champ....check it out: - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
1970 Daily Driver
Holy crap thats fast. Is it true that the powerwheels motors can run up to 20 volts and not burn up. I have a freind that said his sons 6volt jeep has been running of 12 volt for 3 years now with no problems.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 02-26-2009 at 01:54 PM. |
#13 |
Tonawanda 454
My daughter has a Jeep that she had not ridden for at least a year or two now... but when she got the hang of it... she was drifting around the road/circle/culdesac in front of our house... she would come in on the wet grass and let the rear end break loose and hang on, usually she pulled out of it...
now she has a bike and she is becoming a little daredevil... yep shes our beautiful country girl...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
