What shocks to use for 5/7 drop
I am sure this info is somewhere but I am not finding it. I need to get some shocks to work with my 5 inch front and 7 inch rear drop. Anyone have part numbers? Thanks in advance.
Re: What shocks to use for 5/7 drop
bump- Im needing the same info.
" If you aint first your last!" ![]() -1970 c20 lwb (IN PROCESS) *c-notch *3" front springs/5" rear springs/2" blocks -1969 c10 lwb (from in process to parts truck.) -2006 chevy silverado 1500 *22" wheels *3" drop shackles |
Hey guys on mine when i did the flip i just made a new shock mount that allowed the stock type shock to have enough room for proper travel .Hope this helps
72 chevy former 1ton converted to 1/2 ton roller 350 engine , turbo 350 and a 12 bolt on leafsprings with a flip and drop springs ![]() |
Need info for the front shocks. I want a decent set. In the past those drop shocks that you can buy are junk. I have blown up a few of those on other vehicles.
67-72 parts collector,…
![]() Join Date: Nov 2002
thanks lolife
Shoot those list are for the 72 and earlier trucks. I need some for the 73 thru 87 trucks. I have tried monroe's website and its super complicated.
They use the same shock up front.
Just match up the shock with the amount of "spring drop" that you have.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-25-2009 at 09:07 AM. |
What about the rear any ideas?
Try Belltechs website or call Summit Racing.
I don't think they will have a shock for my application as it is approx. 8 inches dropped in the rear. I am still working on the front. I arrived at my measurement by taking what is the supposed stock height from the wheel arch and measuring to the ground. so stock should be 34 inches and I am sitting at 26 inches.
Tire size will change that measurement.
What do you have? Flip kit and a shackle? Use a drop shock for a 6" drop (flip kit), with a shock extender. Do you have a c-notch in the frame?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-25-2009 at 10:26 PM. |
#13 |
I have the c notch I just haven't installed it yet. I haven't driven the truck since installing the flip. I need more hands to get the bed off.
I forgot the tires would make a difference. I checked and I am 1.5 inches lower with the tires. So it's 6.5 inches lower cause I have the shackles with two sets of holes in them. It almost tucks the tire now! I was shocked when I set it on the ground. I am going to move it to the other hole for the full 7 inch drop tomorrow. I emailed Monroe Shocks for some info. I will post it up as soon as I have it. |
