73 Cheyenne Help!
I just got a 73 Cheyenne 3/4 ton. Has the 350 engine in it. The truck runs fine but wont shift into second. It will drive just fine in first. But once you get going fast enough and she tries to shift into second it doesn't happen. Mind you it's an auto. We are going to drop the tranny this weekend. Is their anything we should check out before doing so?
yes, i do
Re: 73 Cheyenne Help!
is the vacuum modulator valve connected to a vacuum port on the engine?? i had my modulator valve line blow off during a back fire and wouldn't do any gear above 1st until i managed to hook the line back up. typically it'll be connected to a port behind the carb, in front of the dizzy
#3 | |
What transmission are you running? That will make all the difference in the world.
I'm not sure. I think it's the 350? I don't know much about it, my dad does. It came with another tranny, the guy said it works fine. It's a 400? tranny ( like I said, I don't know much about any of it lol.) He said the tranny in it was working fine then one day while driving it, it just locked up the rear tires and wouldn't shift into second.
I know its a simple thing but have you checked the tranny fluid? Is it burnt smelling or black insted of cherry? Does it need fluid added?
#7 | |
This will allow you to look at the pan and figure it out easier ![]() |
#8 | |
#9 | |
If it locked up the rear tires and won't go into 2nd anymore I'd say as someone suggested make sure you check the fluid levels. Then I'd say put the rear wheels up in the air (truck blocked well) and see if it would go into 2nd again. If fluid is good and truck still don't go into 2nd then you definitely have a transmission problem and problem something with the gears inside. Either way looks like a possible rebuild of that TH350 |
