Old 02-24-2009, 05:47 PM   #1
centsless
sufficiently talented fool
centsless's Avatar
? for small block to big block swap
I pulled the 283 out of the "72, and installed a 454. It is in and bolted up using the small block mounts. Everything fits fine...except the headers. The right header clears everything fine, the left header is hitting the engine perch...BAD. I am not against denting the tube a little to introduce some clearance, but I would have to cut the front tube in half to get around this one. I have a '71 Suburban with the correct big block perches, but I don't want floor clearance issues with the TH400 trans, and also need the hood clearance for the blower. Anyone have any ideas or solutions for this dilemma?
Thanks!
Bob
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 02-24-2009, 06:29 PM   #2
70rs/ss
70rs/ss's Avatar
Re: ? for small block to big block swap
You can cut the SBC mount and use a piece of pipe to get the curve of the 69-71 BBC mount and then the header will clear. I don't think the BBC mounts raise the engine that much?? I have seen the above mod done to a SBC mount in order to allow the BBC header tube to clear, I wouldn't beeat on the header, just make the mount fit around the tube??
70rs/ss is offline   Reply With Quote
Old 02-24-2009, 08:18 PM   #3
centsless
centsless's Avatar
I was thinking about that. I have a plasma cutter and a mig, so it would not be too big a deal, but was wondering if there were any other avenues first. That may be the way I go.
2003 Suburban
1981 Corvette
Old 02-24-2009, 08:29 PM   #4
67/72junkie
I think you can use 73 up 350 mounts that are almost the same as 72 bb mounts and only have to drill one hole for each side.I bought a 71 gmc with a 454 and thought it had correct 72 only mounts until closer look it had 2 humps spaced instead of 1 in the center like 72 only.
67/72junkie is offline   Reply With Quote
Old 02-24-2009, 08:37 PM   #5
mrh33916
Project '67 454
mrh33916's Avatar
I'm using frame and engine mounts from a '86 s/b suburban, the upper holes line up and you must drill a lower hole. i'm using Flowtech headers with no clearance issues
mrh33916 is offline   Reply With Quote
Old 02-24-2009, 08:46 PM   #6
mrh33916
Project '67 454
mrh33916's Avatar
Here are some pictures,Name:  left motor mount.jpg
Name:  right motor mount.jpg
Old 02-24-2009, 08:49 PM   #7
67/72junkie
looking good thats exactly what I was talking about.
Old 02-24-2009, 08:58 PM   #8
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
That's good news, i was just going to go find my 77 350 towers/mounts to put the 454 in my 70 Blazer project. I had heard that this combination worked.
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-24-2009, 09:06 PM   #9
green724x4
green724x4's Avatar
hey centless, do you have a build thread.
I did a blown big block swap last year in my 72.
love to see some pics and specs.
green724x4 is offline   Reply With Quote
Old 02-25-2009, 04:30 PM   #10
primered_junk
ASE master tech/machinist
primered_junk's Avatar
I jumped on this late, I did one and swapped the mounts side to side, had to drill two holes, but it fixed the issue.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 02-26-2009, 03:09 AM   #11
redneckgirl
redneckgirl's Avatar
I did a build thread...if you click the link in my sig, it takes you there....aren't any updated engine swap pics, since someone is taking his time with the clearance issue....
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King
redneckgirl is offline   Reply With Quote
Old 02-26-2009, 07:46 AM   #12
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I used 72only big block mounts with flowtech hedders with No clearence problems On my 72 truck
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 02-26-2009, 11:25 AM   #13
HuggerCST
HuggerCST's Avatar
Originally Posted by centsless View Post
I have a '71 Suburban with the correct big block perches, but I don't want floor clearance issues with the TH400 trans, and also need the hood clearance for the blower. Bob
I don't think you'll have any floor clearance issues. This link has pics that show the floor clearance on GSFmech's 72 with a 454/th-400, 72 BB engine mounts and a low hump floor. (post #122) http://67-72chevytrucks.com/vboard/s...=271489&page=5
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-02-2009, 10:35 AM   #14
Ron 586
RIP Mr Ron
Ron 586's Avatar
What happened. Any progress on resolving the problem.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
