Old 02-24-2009, 06:43 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
quad carb
whats the best quadra jet carb cuz i have like 6 different ones and since i gotta rebuild my carb i might as well find the best one out of my collection and rebuild it lol BTW i got all these carbs with my truck
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 02-24-2009, 07:00 PM   #2
Chlsnk
Chlsnk's Avatar
Re: quad carb
Get a holly or cheep eldelbrock its worth the money the quadra junks are exactly that. JUNK I have learned the hardway with these trying to get by on the cheep its not worth it.
Chlsnk is offline   Reply With Quote
Old 02-24-2009, 08:51 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: quad carb
Everyone has their own opinion as you can see in this thread;
http://67-72chevytrucks.com/vboard/s...d.php?t=330138
Poke,
Look all the carbs over. Check for wear in the throttle shafts and just over all wear and tear. Pick one that is close to the one on the truck now, Vacuum hose ports/fuel inlet etc.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-24-2009, 09:08 PM   #4
pokethesmot
Re: quad carb
Poke,
they all look purity good just a little dirty
Old 02-24-2009, 09:08 PM   #5
pokethesmot
Re: quad carb
what carb gets good mpg
Old 02-24-2009, 09:29 PM   #6
Restrorob
Restrorob's Avatar
Re: quad carb
Lay them on a table, Close your eyes and spin 6 or 8 circles fast then grab one....
Any carb you keep your foot out of....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-24-2009, 10:34 PM   #7
orbot
orbot's Avatar
Re: quad carb
Specially on a V8
I had a quad on my truck got a cheap holley 600 cfm from a friend and what a difference that was 7 years ago and im a holley guy ever since
orbot is offline   Reply With Quote
Old 02-24-2009, 10:37 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Re: quad carb
If you want to rebuild the Quadrajet---Make sure that it is one made by Rochester and NOT Carter. The Carter models had no brass inserts in the body where the needls pass through and they tend to erode and sluff out around the holes. This makes for a poor transition from the primaries to the secondaries. Pitch the Carter carb body.
piecesparts is offline   Reply With Quote
Old 02-25-2009, 11:14 AM   #9
Storm Chaser
Storm Chaser's Avatar
Re: quad carb
Theoretically, a Q-jet in good condition and tune wold be better on MPG if you keep your foot out of it because the primaries are so small. However, I have only seen this in reality just once- and that was with a new unit from Jet performance. Most of the Q-Jets I've seen around here are busy leaking all over themselves.
On a buddy's truck, I took his Q-jet off and put on a Motorcraft (Holley I think) 2-bbl with a plate adapter and got better mileage without too big of a loss in performance. I believe the MPG increase was due to the old carb being a swap-meet P.O.S. though.
If you're seriouse about MPG though, you might look into a TBI setup or some other form of fuel injection.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-25-2009, 12:44 PM   #10
Damien
Damien's Avatar
Re: quad carb
A lot of Q-jets leak because someone over tightened the bolts and warped the airhorn, body, or base. Sometimes they can be trued with a flat file. If the surfaces are too warped its junk.
You want to check the numbers on the carb to make sure it will work with your engine. All Q-jets are 750 cfm, BUT they have stops because the V6 does not need all of the flow. You don't want a carb for a 262 or V6 on your 400 or a 454 carb on your 400. They have different calibrations.
The checking for play as mentioned above is a good idea too.
You can find some very good information by doing a google search. For about $60 and probably two to three hours of your time to do the rebuild you can have a carb that works well on the street or offroad. Make sure you follow the directions that come with the carb kit and keep everything clean! Take your time setting the float.
The Q-jet has a center hung float making it less sensitive to angles. One of the Off Road magizines did a comparison a few years ago and the Q-jet beat the Holley and Edelbrock.
I have rebuild Q-jets on my trucks and they work great once you get the fine tuning done. You don't have to change the fuel lines or linkages or need adaptors to put them on either.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 02-25-2009, 02:59 PM   #11
pokethesmot
Re: quad carb
no offense to the fuel injection users on the forum but i think id rather have my carb
Old 02-25-2009, 03:08 PM   #12
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: quad carb
hey dude save up sonme denero an get a holley =-)
that made me a happy pollock when i put mine on
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-25-2009, 03:26 PM   #13
willett
Another Day, Another Dollar
willett's Avatar
Re: quad carb
amen to the holleys
i threw a double pumper onto my big block a few month ago and i've no regrets
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-25-2009, 06:05 PM   #14
pokethesmot
Re: quad carb
well im ditching the quad cuz i just got it running and i noticed the previous owner the fuel line threats dint match up so he just taped it in there and i aint having my engine light on fire lol so i think i might go for a holley cuz they seem cheaper so whats a good holley to get
Old 02-25-2009, 08:19 PM   #15
dammitmitchell
the pollock
Re: quad carb
as pm'd 670
get a high rise intake and maaby a throttle spacer plate.
you'll be happy
Army vet 02-08
Old 02-25-2009, 09:09 PM   #16
pokethesmot
Re: quad carb
ooh man i aint got that kinda money lol does any one know a place where i could trade in like 5 q jets for a Holley or something
Old 02-25-2009, 09:14 PM   #17
dammitmitchell
the pollock
Re: quad carb
if youare "in good" with your napa or carquest guys..
there's a noticible amount they can take off the price for you..
mybuddy got his for 10 bucks more then a q-jet..
but.... we spend.. ahem... alot of money there..
Army vet 02-08
Old 02-25-2009, 10:08 PM   #18
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: quad carb
I have a Jet Performance Stage 1 780cfm on my truck and I love it. There are no bogs or stumbles and it's on and off the throttle like a lightswitch. Yes, QJets are harder to tune out of the box, but when they are, you can't find a better carb for the street. Their smaller primaries are what makes them easily adaptable to most any size engine from a 3.8 V6 to a 454. If you decide to go to a Holley, I would not go any bigger than 600cfm. You would also need a jet kit to properly tune it to your engine and a adapter plate to make it work on a stock intake since a Qjet is a spreadbore carb and Holleys are squarebore. You'll also need to modify your fuel line to make it work with the Holley and there may be some carb linkage issues to contend with.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 02-25-2009, 10:32 PM   #19
pokethesmot
Re: quad carb
what would be the easyset/cheapist carb to hookup
Old 02-25-2009, 10:33 PM   #20
Albatrossian
Georgia Boy
Re: quad carb
One of the QJets you already have.
Old 02-26-2009, 12:11 AM   #21
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: quad carb
Edelbrock, you will have to get an adapter for either carb, but don't get an open one, get the one with four holes.
The only rebuilt Q-jet I've seen work good is from a carb repair shop.
But you can rebuild an Edelbrock with good results, I haven't used any Hollys,
and they are not popular around here either, so I can't say about them.
heavychevy79 is offline   Reply With Quote
Old 02-26-2009, 02:13 PM   #22
dammitmitchell
the pollock
Re: quad carb
DO NOT GO BUY a rebuilt q-jet..
nothing but bad experiences with those..
a real big problem lately (this is from my car quest guy)
is that the vaccum secondaries just fail.. shortly after being put back in..
if you really want find a damn good carb guy and take one ot him to rebuild.. and sit down and talk to him...
ask a **** load of questions and never "pretend to know everything" just take and absorbe allll that guy has to say..
and if he likes beer.. get him some beer...
thats why i like small shops those guys will teach you everything.. and anything all because you brought them some beer..
and .. well dude.. might wanna quit "poking smot" it'll free up a **** load of money for your truck =-)
Army vet 02-08
Old 02-26-2009, 03:06 PM   #23
pokethesmot
Re: quad carb
lol ive bean clean for over a month now lol
Old 02-26-2009, 03:17 PM   #24
C-10volvo
C-10volvo's Avatar
Re: quad carb
There is nothing cooler sounding that a properly tuned and jetted 795 quadrajet that's wide open.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 02-27-2009, 09:55 AM   #25
pokethesmot
Re: quad carb
our napa here doesn't even carry carbs i just called every where....man im P@ssed off. I gotta now sell my amp and stuff just to get my truck running cuz i cant find any one that wants my Q-jets...this sucks and if i cant find any one that wants my amp im just gunna have to cover the fuel leak in silicone and hope for the best
