Old 02-24-2009, 09:35 PM   #1
Goble>R-10
Goble>R-10's Avatar
swap
I have an 87 silverado r-10. How hard is a small block to big block swap including hoses and wiring/computer?
Goble>R-10 is offline   Reply With Quote
Old 02-25-2009, 01:36 AM   #2
rfmaster
rfmaster's Avatar
Re: swap
Goble
To swap in BBC you'll need BBC TBI, radiator, etc. Same 1227747 ECM was used to control some BBC TBI applications, but EPROM is different. Also BBC TBI is bigger (52mm vs. 47) and used 90 lb/HR vs. 62 lb/HR injectors used with 350 CID TB.
Harness is the same.
Find a complete BBC donor and do a direct swap - this will make your swap easier. Also, heavy duty BBC did not use knock sensor (KS) - these HD applications used 1228747 ECM. 1228747 had a very conservative spark advance to keep engine from pinging (no KS )
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-25-2009, 01:38 AM   #3
rfmaster
rfmaster's Avatar
Re: swap
Goble
//RF
"The Beast"
