Old 02-24-2009, 10:21 PM   #1
es67chevy
es67chevy's Avatar
How to Remove Tracking Bar Stud
Can anyone tell me if they've had any trouble removing the stock tracking bar stud from the rear diff? It seems that its just seated in the eye and should be able to be pushed out toward the rear, but so far, a solid rebar and 2 lb sledge hasn't budged it. Tricks? Techniques? Am I doing it wrong?
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 02-24-2009, 10:29 PM   #2
larry may
Re: How to Remove Tracking Bar Stud
If its that tight mabe it is threaded into the hole. Last one I removed . I loosed the nut tapped it with a brass hammer a time or two . It fell out. Wow do not know about yours . Good luck.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 02-24-2009, 10:43 PM   #3
Shane
Shane's Avatar
put a torch on it then hit it while it's still hot ...
Shane is offline   Reply With Quote
Old 02-24-2009, 10:52 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Once you get the nut off, just twist the stub with a pipe wrench. Works every time.
Old 02-24-2009, 10:54 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
about the pipe wrench.
--Josh
Old 02-25-2009, 11:19 AM   #6
es67chevy
es67chevy's Avatar
Thank you all for the tips. I will apply these tonight and let you know what works.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-25-2009, 10:59 PM   #7
es67chevy
es67chevy's Avatar
Well, a combination of the torch, pipe wrench, and hitting it worked.
Thanks so much!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
