02-25-2009, 12:42 AM | #1 |
18 Till I Die
1987 Heater core w/AC
Looks like I need a heater core. Did some searching and on the hoses I have hot going in and cooler coming out. I can see the return line into the rad and it very low flow( I mean very little) If I rev it up it does increase but i really have to rev it up. The PO really did no maintenance on this thing.The antifreeze is green but lots of brown crud in there too. I took the hoses off and back flushed it with a garden hose and after about 10 min it started to finally run clear. Did not help at all.
So next is the core. Anybody done one of these? any pics or links?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
02-25-2009, 04:52 PM | #2 |
OL BLUU
Re: 1987 Heater core w/AC
Just did mine last month... went by the instructions in the Chilton manual... to me it was quite simple.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
02-27-2009, 10:27 PM | #3 |
18 Till I Die
Just a FYI. I had to flush the cooling system before I was going to do the core. I had no flow thru the core. I phone the local rad shop and for 100 bucks he flushed the whole system and guaranteed that it would improve the heat. He was right...Wow it will cook you right out of the cab now. so no replacing the core now, on to other things.
Does anyone know why my a/c vents "bleed" some air. They should shut off completly when i go to heat or def. but some air still come out thru them?
02-27-2009, 11:36 PM | #4 |
6.0 powered square
it might be a vacuum line or actuator
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
02-27-2009, 11:57 PM | #5 |
18 Till I Die
I pulled the glove box down and the door near the floor moves when i go from floor to def. then there's a door right behind the glove box that also moves when i go to vent but after adjusting in 20 different places I'm still right back where i started.
Does anyone have an exploded view of the ducting and box?
