Old 02-25-2009, 02:55 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
wobbley flywheel
i just put my goodwrench 350 back in and have driven it for about 3 weeks now. i notice that under acceleration, there is a faint rattling sound from the motor. i got under the truck and noticed that the flywheel was wobbling a bit but the converter was fine. is it common for a flyweel to warp? what kind of damage could this be doing?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 02-25-2009, 03:30 PM   #2
cdowns
cdowns's Avatar
Re: wobbley flywheel
couild be the bolts holding flywheel to crank loosened up// maybe not enough thread lock was used on the bolts
Old 03-05-2009, 10:30 PM   #3
69DISASTER
If it is not loose bolts it could be cracked flywheel (not good). I wouldn't let it go it is not going to cure itself!!!
69DISASTER is offline   Reply With Quote
Old 03-05-2009, 11:05 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
check the converter bolts... more likely to be converter bolts than flexplate to crank bolts.
Old 03-06-2009, 02:17 AM   #5
CCCC
CCCC's Avatar
If it is NOT loose bolts on either, it almost certainly is a cracked flex plate and this is not good for the autotrans. If cracked, probably near or between the purpose holes. This wobble soon would cause wear and then shavings in the trans - pump will send them throughout - then a trans rebuild may be in order. Get a good light and check for cracks - and if cracked, drive as little as possible until you replace it. There is a heavier duty version of the flex plate - I put one in but do not remember the designation. Good luck.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 03-06-2009, 06:28 AM   #6
FYI,manuals use flywheels and automatics use flexplates.I`d suspect loose convertor bolts most likely and flexplate bolts next considering the recent install.If they are tight,pull the trans and check the flexplate.
Old 03-06-2009, 07:44 AM   #7
crm318
crm318's Avatar
i plan on droping the transmission and running the motor and checking the flexplate by its self. i will keep yall posted.
1972 Cheyenne
