#1 | |
Brake question....need answer ASAP please
Working on this truck, dude tells me that hes caliper exploded, which come to find out his rotors were so thin the piston inside of the caliper pushed its self out. Then he let it sit on the side of a road for a few days finding a tow, with the piston out of the caliper and the system open like that....he put new rotors, and a caliper on it, called me over to help him bleed it. Bled just fine, good pedal. Now were ready to go for a drive and bam, no pedal. Goes straight to the floor. Hes telling me that when he put it all back together, there was no brake fluid in the resevoir on on the master cylinder.
Now, Im not certain here, but Im thinking he lost all the fluid and ran the master cylinder dry. If thats the case, just wondering if there is a way to bleed the master cylinder on the truck, that doesnt require hours and hours of pumping on the pedal. Thanks, Mitch-
Re: Brake question....need answer ASAP please
if hes lost all fluid in the master he needs to reprime it, start by taking two brake lines and fitings that fit the m/c and run the lines so they are inside of the resivor then fill the resevor past the lines and pump the brakes this will reprime the master then hook up the originall lines and bleed the brakes.
http://www.cardone.com/English/Club/...er%20flyer.pdf
Try this link. It's the first time I ever tried to post a link, but it's a new syringe available to bleed the MC with it attached to the firewall. It seems quick. I'll be trying mine this weekend.
Too many dreams, too little money. |
