Old 02-25-2009, 09:53 PM   #1
willbilly
Junior Member
67-70 verses 71-71 windshield
Can anybody tell what the differance between the 67-70 and the 71-72 windshield weatherstrip and stainless trim is.Thank's for any HELP!
willbilly is offline   Reply With Quote
Old 02-25-2009, 10:18 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: 67-70 verses 71-71 windshield
I believe the earlier trim goes into the weather strip deeper then the later trim.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-25-2009, 10:24 PM   #3
70Custom10Nut
70Custom10Nut's Avatar
There may be a more technical answer, but yes there are three different shapes to the cab, 67-68, 69-70, and 71-72 are all a little different. Of course to the untrained eye they all look the same, but if your put the wrong seal in it will leak in the upper corners. If any one has the technical explanation feel free to elaborate. Hope it clarified things for you. Cnut
70Custom10Nut is offline   Reply With Quote
Old 02-25-2009, 10:51 PM   #4
willbilly
Junior Member
Thanks guys for the help ,but how can u tell what year the cab REALLY is so far I have found that the truck I have has a 69 title,and a 71 chassis and interior parts.This is the frame off resto from hell so far,but im workin threw it with a lot of help on this site.And the old windshield seal did that seemed to be new did fit like crap in the upper corners .
Old 02-25-2009, 11:05 PM   #5
70Custom10Nut
You got me by the shorthairs on that one. I've had a few people tell me the difference in cabs but couldn't personally tell the difference. Cnut
Old 02-26-2009, 12:32 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
I'm not so sure about this. Standard windshield rubber is the same '67-'72. The custom windshield rubber and trim is different for different years and Chevy vs. GMC. It's do to how the trim fits the rubber for the different years. The cabs for all the years are basically the same, except for some minor differences. Small windows on most '67's The emergency brake handles on I think the '67-'68's. Low hump/high hump. '72 doors. The windshield frames are all the same though.
Beat it to fit,
Old 02-26-2009, 09:20 AM   #7
Sammy
Like said before no difference in the windshield shape. Difference is only in the windshield molding trim. Must have the corresponding rubber for the thin or deeper trim molding. Sure someone will correct me. 71 or 72. I think, is the shallow trim and the deeper trim for previous years. Does that sound right?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-26-2009, 11:56 AM   #8
truckintexas
You are correct Sammy. The original 71-72 Stainless trim did not extend as deep into the rubber seal as did the 67-70. If you are not using the stainless trim, all the seals are the same.
If you want to use the stainless trim, make sure the trim and the rubber seal are compatible. In other words, 71-72 stainless (shallow type) must be installed in a rubber seal that has the shallow channel. And 67-70 stainless (deep type) must be installed in a rubber seal that has the deeper channel.
Michael
truckintexas is offline   Reply With Quote
Old 02-26-2009, 02:44 PM   #9
Musclerodz
And don't buy aftermarket trim, it is worthless. Have that issue now.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 02-26-2009, 02:47 PM   #10
PHAT TONY
PHAT TONY's Avatar
Absolutely, the trim depth goes under the glass(deep) or "above" the glass(shallow)
PHAT TONY is offline   Reply With Quote
Old 02-26-2009, 06:53 PM   #11
willbilly
Junior Member
You guys are awsume thanks for the whats what.Were would be a good sorce for the stainless trim that's not made in china.
Old 02-26-2009, 07:26 PM   #12
Tim Christian
Tim Christian's Avatar
We actually always use the deeper trim but our glass guy can put either in. It is all in the installer and we do use aftermarket trim made by counterparts.
Tim Christian is offline   Reply With Quote
Old 02-27-2009, 09:54 PM   #13
70Custom10Nut
What is the measurement of the shallow and deep type? The reason I ask is I picked up my windshield trim (paid $5.00 complete) about 10 years ago, but can't for the life of me remember what year it came from. It measures 7/16" from the front to the rear (the part that is inside the seal). I'm finally going to be getting my new windshield and want to get the right seal. Cnut
Old 02-27-2009, 10:22 PM   #14
70Custom10Nut
Old 02-28-2009, 12:02 AM   #15
Sammy
I had both sets of trim but no longer have them out to look at sorry.
Someone have both sets to measure? I thought the deep one was about 1/2 in, shallow newer trim around half that? But never actually stuck a ruller on it.
Old 02-28-2009, 12:07 AM   #16
PHAT TONY
PHAT TONY's Avatar
I believe the shallow trim to be 1/4 to 5/16 or there-abouts.
Old 02-28-2009, 12:38 AM   #17
72blue
72blue's Avatar
I have a 72 and the trim is installed now, but I know that it was not 7/16 deep at all...was definitely less. Do yourself a favor and get a good quality seal that your glass man advises. I had a seal that I bought and he declined to install it...said every time he puts one of those in a 67-72 has those unforgettable corner issues. Took his advise and so far so good.
72blue is offline   Reply With Quote
