Old 02-25-2009, 10:04 PM   #1
4x4man09
73 door swap question
I have a 73 c20, I read on a different site that only doors from 73-76 are interchangable. I have an 85 suburban sitting in the drive way, what is the difference in the doors other than the door panel area?
4x4man09 is offline   Reply With Quote
Old 02-25-2009, 10:14 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: 73 door swap question
other then the door panel area nothing at all
ont_guy_38 is offline   Reply With Quote
Old 02-25-2009, 10:16 PM   #3
4x4man09
So they can be used? On the other site it says that it wont work. But since it will then I don't have to buy any new doors! Sweet!
Old 02-25-2009, 10:20 PM   #4
4x4man09
Would you happen to know what years are interchangable for most parts? I need 2 doors, front fenders, a hood, and tailgate. I saw a post for an 86 bed (wide?) and was interested in it. Maybe a site that can help better then the ones I have found?
Old 02-25-2009, 10:35 PM   #5
ont_guy_38
ont_guy_38's Avatar
Yes the doors will fit for sure,fenders and hood will have to be from a 73-80 model truck.The 86 bed will fit also .Now with a little work (providing the suburban parts are good) you can put the whole front end on,it will pretty much bolt on the trickiest part is mounting the hood hinges in the cab
Old 02-25-2009, 10:37 PM   #6
Restrorob
The One And Only !!!
Restrorob's Avatar
I asked BB73 (Jeff) about this a while back when looking for a cab shell for my 74 (he knows his stuff) and this is the reply I got;
Originally Posted by bigblock73
Cab breakdown is 73-80 & 81-87. Your doors and front clip will bolt up to a 81+ cab no problem. It is more difficult going the other direction (81+ front clip on older cab).
Maybe you should go back to that other site and set them straight on parts interchanging. LOL
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-25-2009, 10:58 PM   #7
bigblock73
yeller
bigblock73's Avatar
73-76 door guts are different than 77-87 (88-91). The 73-76 window crank stalks are shorter, roller channels welded to the inside of the door are different as are the window regulator rollers themselves. Of course the door panels are different too.
You can swap complete 85 doors to your 73 no problem, it is when you start interchanging parts that you will run into trouble.
bigblock73 is offline   Reply With Quote
Old 02-25-2009, 11:00 PM   #8
4x4man09
Ok I'm confused now. Will it work with using everything? Like taking the whole door off, window and all and just bolting it on the 73
Old 02-25-2009, 11:01 PM   #9
bigblock73
yeller
bigblock73's Avatar
I edited my post while you were typing your reply...look above.
Old 02-25-2009, 11:19 PM   #10
4x4man09
Haha alright, thanks guys for the help! I'll be sticking around as I'll need more help lol.
Old 02-26-2009, 08:24 AM   #11
mhicks
mhicks's Avatar
Yes, change it all. I put some electric '86 doors on my '73 before I had it repainted.
mhicks is offline   Reply With Quote
