Old 02-25-2009, 11:16 PM   #1
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
ONE really crazy idea but really can it be done
Ok heres the idea minus money and time its more of can this be done with out causing me to go insane (anymore then i already am for thinking of this)
Take one 1965 short bed fleet (leave the body all stock) gonna have to tub this but still want wood floor just causes
then take one GMC trash truck (yes i have one laying around) take oh i dont know the big block 427 out with the trans
install into truck (most likely will need a custom frame)
this is what i do know the deck on a truck motor sits higher then that of a car why i really not sure but i know it can be made into a torque machine with what i was told was a cam but not sure (big blocks are new to me)
The trans yeah that more for fun if i could find something to use instead ok thats fine
but in all ideas is this able to be done. or has it please make fun its ok i know its a crazy dumb idea but heck if i have the parts sitting right
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 02-25-2009, 11:20 PM   #2
low900rr
Re: ONE really crazy idea but really can it be done
theres more than one guy on here with a big block in their truck............im not seing the crazyness here.
My builds
69 stepside.......2wd to 4wd
http://67-72chevytrucks.com/vboard/s...d.php?t=330675
and the new 66
http://67-72chevytrucks.com/vboard/s...d.php?t=302321
low900rr is offline   Reply With Quote
Old 02-26-2009, 12:17 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
with low900rr.....BB drop right in as the frame is the same thru 72, generally speaking.
The weird thing is the truck 427. Tall deck motor has an extra ring and super tall piston. Those engines also may have a gear driven cam/distributor set-up that has reverse rotation. They use a different intake manifold to cover the extra 1.5(roughly) of stroke.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-26-2009, 12:25 AM   #4
LILRED66
LILRED66's Avatar
I find it hard to follow your post, but I think I get the idea, however, I am not sure what is so "out-there" with installing a big block in a 4-5-6 Chevy truck, let alone creating a torque monster. GM did this with the 292 High Torque six cylinder and the SM420 or SM465 in the '60-'66 Chevy trucks, hence the name stump-puller.
In any case, keep us posted on your zany ideas and we'll see where it goes.
LILRED66 is offline   Reply With Quote
Old 02-26-2009, 12:57 AM   #5
68c10owner
68c10owner's Avatar
I think what he`s getting at is putting the tall deck bbc in a regulat truck. not that much trouble these days. Alot of guys are running tall decks in cars so putting one in a truck isn`t a big deal. The problems with the tall decks are the pistons. I don`t remember which way it is, possibly both but if you use a longer rod then you can use regular pistons. Might be the longer stroke you can use regualr pistons but I`m leanign towards the rods. I`m not a bbc guy so I don`t pay too much atention to them. If the trans in the garbage truck is a automatic then it`s a th400 and that will bolt in your truck too. good luck.
Anthony
68c10owner is offline   Reply With Quote
Old 02-26-2009, 07:36 AM   #6
Srubydo1986
The Crazy Machanic
well true to bb have been put in but just thinking the tall deck motor might be odd as for the trans its manual 5 or 6 speed have no idea didnt actually go through the gears.
newest additions
Old 02-26-2009, 10:14 PM   #7
502tripower
502tripower's Avatar
No problem with the BBC in the truck and the tall deck is even better because you can use a the 4.375 Crank to make 540 CI......
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 02-26-2009, 11:29 PM   #8
apachedaddy
apachedaddy's Avatar
hard to follow i think the little drunk man icon says it all lol
apachedaddy is offline   Reply With Quote
Old 02-27-2009, 07:12 AM   #9
Srubydo1986
The Crazy Machanic
cool if makeing the big block fit wont be all that hard then this should be alot easier then.
and thx for the tip on the 540 might just have do that.
one more thing i plan to get the truck as low as i can to the ground with out body droping the truck.
the reason for the build is simple enough the truck is my great granddads the motor is from my grandfathers trash truck. and to build it all will come from what my dad has taught me so far.
its a memorial truck to all three now to just find the time to get it started with all the other projects i got
newest additions
Old 02-27-2009, 07:56 AM   #10
sleepiejay
Would the tall deck big block bolt up to a TH400 from a 350 ?
Does someone make headers to fit a it in a 65 ?
sleepiejay is offline   Reply With Quote
Old 02-27-2009, 02:21 PM   #11
502tripower
Yes the TH400 will bolt up. I am not sure about the headers with the tall deck.
98' FXD
2002 2500HD
Old 02-28-2009, 12:37 AM   #12
Captainfab
60-66 Nut
Sanderson makes headers that work with a tall deck. That's what Stacey David used on Copperhead with the 572.....which is a tall deck. I don't remember the part number off hand, I've got it at the shop.
Putting a tall deck BB in a '65 most likely will require moving the engine ahead some to clear the firewall. Definitely doable.
