Old 02-26-2009, 12:35 AM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
Radio Relocation
I'm feud up every time I drive my truck where my radio is :'(, I hit my knees and also I almost drive off the road when I adjust the radio, since I'm not using the a/c heater equipment, I decided to move my radio where it was, also I will be showing how I installed my gauges that I did last year
I will be using a 89-91 bezel, it going cover the mess up where the past owner installed a radio, I still need fasten the radio a make a new piece of diamond pate for the gauges and to cover up the factory radio
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-26-2009, 02:18 AM   #2
andrewmp6
Re: Radio Relocation
I would have mounted it higher up then that and put the heater switch under it.
andrewmp6 is offline   Reply With Quote
Old 02-26-2009, 04:51 AM   #3
AceX
>130dB Moderator
AceX's Avatar
The guys that did the install on my truck had talked about doing a bad ass double-DIN unit in that exact location.
Since you use a seprate set of heater controls it works out great. Now I know what it would have looked like...
When I get another truck, I'll be doing some cool stuff like that.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 02-26-2009, 06:08 AM   #4
S10Fan
Old Heap Driver
Tell me more about the heater.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-26-2009, 09:33 AM   #5
Storm Chaser
Storm Chaser's Avatar
I'm thinking about mounting mine where the center AC vent would be- I figured it would get the radio away from the steering wheel so it wouldn't be so awkward to put a CD in.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-26-2009, 11:19 AM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
When I HAD a radio in my 78 that's where I put it. If you are crafty it will look like it goes there from the factory.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-26-2009, 12:25 PM   #7
Storm Chaser
I got the idea from my buddy's truck, only we mounted gauges there on his. When we do mine, the radio is going there, and switches for the dump bed and aux lights will go in the stock radio location.
1988 R2500 Crew Cab
Future plans-
Old 02-26-2009, 02:42 PM   #8
79Silv4x4
Workaholic
79Silv4x4's Avatar
You live in Texas, where's the AC controller
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 02-26-2009, 03:45 PM   #9
flamingbig10
6.0 powered square
I was going to mount it there but the metal dash curves there
Its a http://store.summitracing.com/partde...5&autoview=sku
here some installed pics just have to hook up hoses and make a defroster vent
there about 8 inches from the steering wheel.
If I can't make it look good with diamond plate then I'm going to fiberglass it
there right here one of these I'll get my door panels that I ordered from capt from the upholster
Aaron
