02-26-2009, 08:44 AM | #1 |
spring pads, if thats what their called
i was just wondering what the plastic or rubber pads between the leaf spring were made of and where i could purchase some. thanks for any light you can shed on the topic
02-26-2009, 11:34 AM | #2 |
Happy to be here
Re: spring pads, if thats what their called
I belive they are Delrin which according to Wikipedia is atually Polyoxymethylene (POM), This is an engineering plastic, a polymer with the chemical formula -(-O-CH2-)n-. It is often marketed and used as a metal substitute. Delrin is a lightweight, low-friction, and wear-resistant thermoplastic with good physical and processing properties.
I would check with the local auto parts, or spring shop.
02-26-2009, 12:52 PM | #3 |
Poises for spring liner...http://www.posiesrodsandcustoms.com/
Spring pads, equals spring shop only, find your local big truck spring company, they will have them. Mick |
02-26-2009, 02:15 PM | #4 |
on what part of the spring do they go, mine dont have them and was just wondering if it was mandatry
02-26-2009, 10:06 PM | #5 |
Happy to be here
They are normally used to separate friction points. You will find the between the spring pack and the bottom "overload" leaf. Some spring sets have the pads between the longer top leaves as well.
Do you "need" them? Probably not, but you might get a squeaky spring if you don't have them.
02-26-2009, 11:27 PM | #6 | |
02-26-2009, 11:54 PM | #7 |
well i ask because i am getting my leaf spring powder coated so i figure these would help between the springs, to save the coating
02-27-2009, 03:06 PM | #8 |
is powdercoating the spring ok?
02-27-2009, 07:53 PM | #9 |
Happy to be here
I see no reason why not. The oven temps to bake the powder shouldn't be high enough to impact the spring tension.
03-02-2009, 01:29 PM | #10 |
Not completely sure if this applies to leaf springs or not, but I know if you do a regular powder coat on coil springs....they turn stiff as heck!!
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
03-02-2009, 04:11 PM | #11 |
Happy to be here
Jeph- What's the alternative? I see them powder coated so is there is a low temp version?
03-02-2009, 06:24 PM | #12 |
I believe so. I'll ask Justin. I know that whomever manufactures our springs for our coilovers for us (I should probably know that right, LOL) said there is some special way they powdercoat them
