Old 02-26-2009, 09:08 AM   #1
tim21391
tim21391's Avatar
filler ?
im thinking to use this filler that has kevlar and fiberglass in it to go over the weld on cab corners first then use normal light weight filler after that?? does that sound like a good idea??
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 02-26-2009, 09:54 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: filler ?
I'm not familiar with the filler you are talking about. Have a brand name? I always use a product called Metal To Metal for the first coat. I guess it wouldn't matter what brand you used as long as it didn't absorb moisture like the regular body fillers do.
LockDoc
Leon
Old 02-26-2009, 02:14 PM   #3
tim21391
tim21391's Avatar
Re: filler ?
its evercoat/everglass i think is what its called its real dark green
