Old 12-14-2002, 02:39 PM   #1
C10N.UT
Question poly sway bar bushings?
hi
I was wondering what poly swaybar bushing ppl are running.I got a 3/4 ton front bar off the local salvageyard the other day.Its a 1 /14" bar,and going thru the nearby autozones' and checkers have netted only the energy suspension bushiings that say not for use on fullsize trucks.
C10N.UT is offline   Reply With Quote
Old 12-14-2002, 03:24 PM   #2
78SilveradoSWB
78SilveradoSWB's Avatar
Arrow
C10n.UT, I got a used 3/4 ton front bar recently via Ebay, and refurbished it with black Hammerlite paint and got some Energy Suspension bushings with grease fittings. After reading the instructions it said not for full size trucks or Mustangs.
They look like they'll fit, anyone out there has any further input?
78SilveradoSWB is offline   Reply With Quote
Old 12-14-2002, 04:21 PM   #3
pkbinplano
pkbinplano
pkbinplano's Avatar
I put an 1 1/4 sway bar on mine with Moog bushings. Worked like a champ. Non greasable . Truck drives great. Do a search. I posted part numbers.
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 12-14-2002, 04:23 PM   #4
pkbinplano
pkbinplano
pkbinplano's Avatar
http://67-72chevytrucks.com/vboard/s...light=sway+bar
Go here oops no p/n's For a 1 1/4 sway bar takes two sets of Moog bushings p/n k6476. They come 2 per set.
Old 12-14-2002, 09:42 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
The part number for Energy Suspension anti-sway bar bushings for a 1-1/4" bar is 3-5177G. These are the black ones which are graphite impregnated. The two which fasten to the frame will have zerk fittings so you can grease them if you ever need to.
The red ones, which don't have graphite, is 3-5177R, and have zerk fittings too.
The ones you are talking about are the universal bushings and won't work on our trucks.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-15-2002, 03:40 AM   #6
C10N.UT
Thanks guys....
Swervin: do you buy chance have the p/n for the bushing kits on the endlink side?(the lower control arm by chance?)
PKinPlano:Ill have to check them numbers out when i get to work monday and see what i can get those for at my dealer cost!The aftermarket parts shop we go thru carries alot of moog
Thanks for all the help!!
This board rocks!
Old 12-15-2002, 04:32 AM   #7
78SilveradoSWB
I think they are the same ones 3-5177G or 3-5177R that go on the A-arms and the swaybar bracket.
Old 12-15-2002, 11:09 AM   #8
pkbinplano
pkbinplano
pkbinplano's Avatar
I think they are only about 15 beans a pair
Old 12-15-2002, 01:03 PM   #9
swervin ervin
The part number above are for four bushings, complete with brackets. The two on the frame will have zerk fittings, the two on the lower control arm don't. They will be like this photo, except for a 1-1/4" bar.
Mike
1985 Chevy C-10
Old 12-15-2002, 01:48 PM   #10
C10N.UT
awesome
Thanks again guys!!
Like is said before.....
This board Rocks!
Old 12-16-2002, 02:47 AM   #11
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
Wow! that swaybar looks alright, I better see if I can find one. What is the biggest factory replacement one available? Anyone know?
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 12-16-2002, 05:20 AM   #12
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I think 1 1/4 is the biggest.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
