02-26-2009, 11:54 AM | #1 |
Just ordered my dropmember!
All,
I just ordered my dropmember from Porterbuilt! Can anyone recomend some good 3 inch drop spindles? Also, what parts would you guys recomend? I am going to stand by for the Porterbuilt Control Arms, but any and all info on other parts would be greatly appreciated. Rigo |
02-26-2009, 12:50 PM | #2 |
67-72 parts collector,…
Re: Just ordered my dropmember!
I like Belltech for 3" drop Spindles. What year truck are you working on?
02-26-2009, 01:19 PM | #3 |
Another nod for Belltechs.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
02-26-2009, 02:29 PM | #4 | |
You are going to love your Dropmember! I do!!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
02-26-2009, 04:03 PM | #5 |
Active Member
I have djm 3" spindles. never had a problem and they keep the track width in check
02-26-2009, 08:35 PM | #6 |
Happy to be here
I agree. I have had several sets of DJM 3" spindles and no problems to speak of.
02-26-2009, 09:38 PM | #7 |
1970 Chevy C10 SWB. What do you mean by they keep the track width in check? Is there something i should know?
02-26-2009, 09:45 PM | #8 |
The DM narrows the track width. I don't think drop spindles would narrow it anymore though.
I ordered my C4 DM as well. Can't wait to get mine in.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 02-26-2009 at 09:47 PM. |
02-26-2009, 10:16 PM | #9 |
Guys, this is going to sound a little crazy, but what year spindle do i buy? Since i am changing the whole crossmember, dont i get to chose a newer year spindle?
02-26-2009, 10:48 PM | #10 |
that depends on your control arms.
02-26-2009, 10:58 PM | #11 |
Ed, enlighten me please. What do you mean, it depends on my control arms?
02-26-2009, 11:51 PM | #12 |
depends on what year control arms your using....or what year ball joints in em if you switched em.
My builds 69 stepside.......2wd to 4wd http://67-72chevytrucks.com/vboard/s...d.php?t=330675 and the new 66 http://67-72chevytrucks.com/vboard/s...d.php?t=302321 |
02-27-2009, 12:05 AM | #13 |
Active Member
also depends on what brake rotors you plan on using... I dont remeber the years but they switch between 1" and 1.25" somewhere in the 70's or 80's... or maybe thats just th heavy half ton? I dont know, it was soo long ago that I did all this stuff. and about the track width. I think I remember that te belltech's push the wheels out further then stock and the djm's either narrow it or keep it close to stock... once again, I cant remember exactly what the deal is...
02-27-2009, 01:47 AM | #14 |
you need to know what year balljoints and what width rotors 1.25 or 1"
02-27-2009, 10:51 AM | #15 |
You need to call Nate to make sure what setup your are getting. I believe, but would double check, his new setup requires 73-87 lower control arms and that would be a more economical route to go because 71-72 spindles are almost a third more expensive (you save about $100).
I bought my spindles (DJM 3'') from Godfather Customs and I negiotiated them to $220 shipped. Make sure that you insist that they send you that particular brand because they will send you Mcgauthy spindles. I sent them back and then got the DJM. Lastly make sure you what size rotor you are running.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
02-27-2009, 11:55 AM | #16 |
Personally I like the ECE spindles. I also know Nate Porter advertises with ECE because he believes in their stuff and that says a lot to me!
Kevin LFD Inc. |
02-27-2009, 12:54 PM | #17 |
If you have the "new" Dropmember V3 you have to use 73-87 lower stock control arms or aftermarket tubular arms. (The uppers can be 67-87)
You might as well run 73-87 drop spindles also. Just make sure to get the correct spindle for the correct width of rotor you plan to use. (either 1" or 1-1/4")
02-27-2009, 03:11 PM | #18 |
Guys, I am standing by for the Porterbuilt control arms. I will find out which spindles i need then i guess.
What bags/compressors/other stuff will i need? Its going to have 20 inch wheels and lay frame. (i hope) |
02-28-2009, 02:34 PM | #19 | |
Texas Big Wig
Just as a rule of thumb I like Slam Specialties RE-7s in the front & RE-6s in the back You will either need a switch box or some sort of electronic controller to control your valves You will need valves, how many depends on what you want your truck to do & what kind of valves you get If you are just cruising you wont need a very big tank or compressor, but if you wanna play with it, obviously you will need bigger better stuff Also air line size, valve size, & other things depend on if you wanna play with it or just cruise So just figure out what you really want out of your air ride & prolly start a new thread to get more replys |
