Old 02-26-2009, 12:36 PM   #1
Storm Chaser
Storm Chaser's Avatar
Who knows dump beds?
A guy was just here to buy some wheels from me and he had a truck with a dump bed. The truck was a manual with a PTO driven pump for the dump. This is the way I've always seen it. But... what if you wanted an automatic? How is it done in that case?
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-26-2009, 01:42 PM   #2
Sinisterspeed
Sinisterspeed's Avatar
Re: Who knows dump beds?
With an Automatic you just use a pump that is self contained. (just like the ones on lift gates,fork lifts, and Suspension set ups) It usually runs a 12v motor on the end of the pump to drive it.
The way I have seen it would be a hydraulic pump that pressurized 1 single line to go up and then hit the switch the other way and let the weight of the bed bring it back down. (1 pump, 1 dump, 1 3 way switch, 2 hydraulic lines) You can either buy these pumps with a number of different gears in the pump head or you can use one from a lift truck. depending on which you use make sure the cyl and hoses match the pressure it puts out.
I have seen 1000 psi on lift gate pumps, 2-3000 on suspension pumps, Custom pumps and some oddball ones I have seen as much as 6000.
Hope that helps..??
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 02-26-2009, 03:30 PM   #3
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
if you have an automatic 4X4 with a 205 transfer.You can still use a PTO
powerdriver 1958 is offline   Reply With Quote
Old 02-26-2009, 03:44 PM   #4
Sinisterspeed
Agreed, I forgot about the obvious... duh.
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
My Longhorn Build
Old 02-26-2009, 04:40 PM   #5
Dooley
Dooley's Avatar
If you have an automatic transmission 4x4 and a 203 tc you can run a pto also. As another alternative you can run a motor driven pump.
Dooley is offline   Reply With Quote
Old 02-27-2009, 12:49 AM   #6
andrewmp6
I would use http://www.loadhog.com/YourTruck.htm i like there kit since it uses air and you can't tell its a dump bed truck tell you lift it up.
andrewmp6 is offline   Reply With Quote
Old 02-27-2009, 10:24 AM   #7
Storm Chaser
Well, the truck is a 2wd, but my mind changes more than a woman in a clothing store, so this all might end up on a 4x4 at a moment's notice. Thanks for the info guys.
1988 R2500 Crew Cab
Future plans-
