Old 02-26-2009, 07:16 PM   #1
Mister laugh
Dumb driveshaft question
Well i was planning on starting my t-5 swap this weekend, so i went to the yard today to find a driveshaft to shorten because i dumped $500 bucks into "rebuilding" the one in the truck now last year.(don't ask) So there is no point it having that one chopped up. Long story short i get to the yard look under all of the 67-72's they have there (2 70's and a 67') and none of the carrier bearings look the same as mine. So just for kicks i go look under a 73-87 and it looks like mine. I made the decision to take a 67-72, but now in retrospect don't remember my cross member having a place to hang it from. If infact the mounting point for mine is MIA is it possible to flip it over drill the holes on the cross member and mount it "upside down"? Or is it difficult to remove the hangar portion from a truck in the yard?
And i may aswell ask here. The truck i pulled this from had tinted glass (factory) in it, is it worth going back to get? And it was slightly greenish that is the tinted glass right? It had the option on the spid.
Mister laugh is offline   Reply With Quote
Old 02-26-2009, 07:36 PM   #2
Green Machine
Green Machine's Avatar
Re: Dumb driveshaft question
Do you have any pics ? The larger style hanger bolts mount side to side and the other smaller one mounts front to back. I think 3/4 ton 4 speed had the larger hanger.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-26-2009, 08:21 PM   #3
Mister laugh
No i don't have pictures handy my truck is unfortunately 250km away from me, or i wouldn't have asked i would have just checked. But yes the driveshaft on my truck mounts side to side not front to back, and is a HUGE pain in the ass to get in there almost like it wasn't made for the truck. My truck was originally a 4spd but it is a half ton not a 3/4. I think i am going to rig up a way to mount this driveshaft one way of another i like it much better than the larger one. It is easier to install and remove and has less rotating mass.
Old 02-26-2009, 08:32 PM   #4
jbristo67
resident oilfield trash
jbristo67's Avatar
Why dont you just run a 1 piece
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-26-2009, 09:08 PM   #5
Mister laugh
My truck is a longbed i have been told by many reputable driveshafts a one piece is too long and will cause binding issues. That and i am a poor colledge student.
Old 02-26-2009, 09:21 PM   #6
Andy4639
Old member
Andy4639's Avatar
The only center bearing I have messed with is the one that bolts up in line with the drive shaft.
The one on the right is for a 71 two peice shaft I know.
LEFT PICTURE '73 to current Ford, GMC, Chevy, and Dodge trucksRIGHT PICTURE '58 to '64 Chevy cars and '58 to '72 Chevy trucks
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-26-2009, 09:47 PM   #7
Mister laugh
The one on the ledt is what was on my truck currently. Apparently it occasionally came in 4spd half tons. The right is what i have on the driveshaft sitting in the garage.
Old 02-28-2009, 11:30 AM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
so instead of putting a new trans yolk, shortening/lenthening ballancing a 1 year old shaft. youre going to rebuild a junkyard shaft? that will probably need shortened/lenthened, all new u-joints, slip, stub, ballance, maybe trans yoke, maybe end yokes, maybe retubed, and reengineer a carrier bearing mount?
sounds pretty backwards to me.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-28-2009, 04:37 PM   #9
Green Machine
The "side to side" bearing is a much stronger design than the little one that bolts front to back. Unless you run one of the better ones on the right, we have one on one truck, but the bearing and aluminum housing are about $100.
I'm prettty sure you could grind the rivets and remove the old mount and replace it if you want to.
