PITbut
Air baggers. Need help asap. Valve wiring?
I figured this was pretty straight forward. I have SMC valves. One red wire and one black wire per valve. I figured you ground the black wire and put the red to hot if you want it to open. That doesnt work, so before i keep screwing with it. How do you wire them? Is the black go to positive and the red to ground???
#2 | |
PITbut
Re: Air baggers. Need help asap. Valve wiring?
PITbut
Well, just put the black to the negative on teh battery and the red to the positive. It works. I just dont get why it wouldnt work the way i had it. THe black grounded on the frame to bare metal and the red to the positive on the battery.. IDK...
senior member
stranger things have happened on my gc extreme valves the instructions werte wrong for the power and ground
69 GMC bagged |
check out the suspension section you should find your answers there if not airbagit.com has good schematics drawn up
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
black to ground, red to power ...
#7 | |
PITbut
Shane, i had the black wires grounded to the frame. Bare metal. I applied power to the red and nothing. Just doesnt make sense. I dont have my battery installed in the truck, so does that mean my frame is not grounded??? ONce i took the grounds off, hooked them to the negative on the battery, then the red to power, it works. Im just wondering why the darn frame grounds arent working. |
#8 | |
good luck! |
PITbut
I figured that out this morning. Thanks shane. I had my grounds all nice and neat and ripped em all out. ahaha. Oh well.
