![]() Join Date: Jul 2007
How Do I Transport a Long Bed Box?
I am buying a pristine long bed (just the bed) and I would like some feedback before I mess it up during transport. I have searched and have found only one picture of a bed being transported. It looked like someone used cement blocks and 2x6's for blocking then strapped all 4 corners to a flatbed trailer. I have a 16' flatbed (should be enough) and I'm wondering if I could use jack stands (4) to make it level then strap it down to my trailer Or. should I turn it over and let it rest on the rails. Turning it upside down would be a bit of a hassle. I have seen others transport them standing on the front panel but it looks like it might act like a sail in the wind.
Any ideas would be greatly appreciated !!!
It's Not Rust, It's Patina!! 1967 ![]() 2008 ![]() |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: How Do I Transport a Long Bed Box?
I would put some cushion under the rails and turn it upside down, strap it to the trailer and head down the road.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() Last edited by Bishops Trucks; 02-26-2009 at 11:06 PM. |
Eat My Rust
Yeah, I agree flip it over, and lay it on some kind of padding, tie it down and head down the road.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
I have a radical idea!
I know said it would be hassle to turn it over, but still yet, that's only way I would transport one. My brother were able to take the LWB bed off the donor truck for my '67 C-30. It was little tough, but we are both big guys. I believe 3 guys could do it comfortably.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
![]() Join Date: Oct 2005
I bought a rust free box a while back...I used a snowmobile trailer,put it on and stacked doors and fenders inside...worked great...!!!..
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
If you are pulling the trailer with the long bed truck, I would unhook the trailer, leave it at home, turn the bed upside down and strap it to the top of the bed on the original tow vehicle. It would save fuel and the aggravation of having to pull an empty trailer all the way there. I don't know about you and your rig, but my trailer empty buckboards my truck worse than when it is loaded.
Good luck on bringing it home.
Kevin Korff Evansville, IN 47711 1997 Silverado 3500 LWB Vortec 454, headers 4.11 posi. Victory Red WOW! 1976 Oldsmobile 98 Regency four door 42,000 miles original paint. This is still a car! 1990 Oldsmobile 98 Touring Sedan 34,000 miles 1983 Hurst/Olds 30,000 actual miles 2013 Ford Taurus SHO 1972 Hurst/Olds-a work with no progress 1972 Oldsmobile 442 Convertible 455 |
i have seen guys transport them by putting an old mattress and some other stuff to rais the bed up high enough not to mess anything up ans then using old blankets to cushion the ratchet straps holding the truck bed on so as not to mess up the paint
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
The Older Generation
I just moved mine on a small trailer yesterday. I built two framework supports and put them under the bed. Wish I had taken some pictures. The supports are 12" high, 18" wide and 4' long. I set the bed on the 12" high side to transport and on the 18" high side to do the body work and paint. That way we don't have to take it off the trailer to work on it. LockDoc
Resident of Here
Lay the cross sills on blocks. Dont have to tip it over, and you dont bent the bedsides. Just remember to strap it down.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
![]() Join Date: Oct 2002
I couple strips of old inner tube layed on your present bed rails and a couple 2x4s .Turn it upside down and strap it down.The trailer is just a hasel as mentioned.I have hauled several this way without a problem.
someday it will be done!
I trailered one across half a province upside down.Worked great for me,had a tractor to load it and a skidsteer to offload though so that made it real easy to turn over.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#13 | |
![]() Join Date: Nov 2004
Geoff can attest to this... when I arrived to pick up my bed the guys at the bodyshop where it was stored looked at me funny and said... "Ummmm, you know that bed not's going to fit in that trailer, right?" Being the smart ass that I am, I said "sure it will" then just smiled as I started laying out my pre cut 2x4's ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-27-2009 at 01:36 AM. |
#14 |
![]() Join Date: Jan 2002
I turned a shortbox fleetside over by myself, so a longbox can't be too much harder.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#15 |
Under Construction
flip it over, and strap it down as redneck shows. BTDT many times. take a couple of buddies with you., buy a case of beer, and some burgers. and your set.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#16 |
Born Psycho
![]() Join Date: Feb 2001
i hauled mine on top of my other longbed. i cut small stakes for each pocket so they would stick up a few inches, sat the new bed on top of the stakes and tied it down. it never moved at all on the road home and some of the roads were pretty rough.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#17 |
![]() Join Date: Dec 2008
I have flipped it, and set on 4 wheels, but by far the easiest and I think safest is to grab 2 or 3 pallets and strap it down to your trailer...
Flipping a bed over makes more chance of dropping it in my opinion. A trailer is usually just a foot or two of the ground and therefore easier to load, you do not want to hear Uh-Oh from a hired hand do you? BRING PLENTY OF HELP , I think 4 guys minimum, I have done it with two, but it is not rel fun. |
#18 |
Firefighter
Turn upside down and haul it as pictured above, I have hauled several like this and never had a problem!!!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#19 |
G.M thought that the best way to support one was by the cross members under the bed? I will have to side with G.M ..... But then again I don't really like the idea of straps bearing on metal that I will have to straighten ot later, JMO (and G.Ms)
#20 |
Saving 1 truck at a time!
This is a shortbed box/truck but use a longbed truck. Thanks again to Frenchblue72 on far left.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 02-27-2009 at 11:39 AM. |
#21 |
Wow!!!!
Thanks for all the replies!! Since I have a short bed Silverado, I think that strapping it to my truck would be difficult....cool idea however. 67ChevyRedneck.... 2x4 cross members on a small trailer also very cool. My trailer is completely flat and tows well so padding and upside down sounds about the easiest. Snowmobile trailer.....perfect!!! People in Missouri won't know what I'm talking about however stllookn.... Cool!! With my luck the bed would be on the ground in 2 miles. Again, thanks for all the replies and pictures (please keep them coming). This definetly helps me and I'm sure it will help someone else in the future.
#22 |
![]() ![]() Join Date: Jul 2002
If you use the bed and your truck bed is the same style, you can put some short 1x2s in the front stake pockets and it will help secure it from sliding also.
I hauled mine 8 hrs from TX back to MS and never even flinched.
#23 |
Snowmobile trailer worked the best for me!!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
#24 |
Again, thanks for all the input. When it came right down to it, I had to set it upright and just strap it down. This way I could fill the box with goodies. Worked very well and seemed very solid so no worries.
BWT, take a look at the crap I had to go through to get this thing!!! Snowing, blowing, icy roads, white outs and 2 wd. Man it was great!!
#25 |
More Bed pics
