Old 02-27-2009, 10:57 AM   #1
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
64 lwb frame
Alright I'm trying to figure out how much room is behind the rear end on a long bed. I would like to put a blazer tank and my air tank if I can behind it. Can someone tell me the size in Inchs' behind it. The air tank I'm using is a 8 Gallon 8 port. Specs:
Length - 32"
Diameter - 9.5"
Height with legs - 11.5"
I dont have the truck in front of me since I'm in Iraq right now. I'm wanting to order the blazer tank before I get home in a week. thanks for the help!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 02-27-2009, 12:41 PM   #2
ruffrida2005
Re: 64 lwb frame
Ttt
Paul
Old 02-27-2009, 01:18 PM   #3
jason65
Registerd User
jason65's Avatar
Re: 64 lwb frame
I dont know, but I have seen a few threads with people that did it. All I can say is do some looking around. Search it.
jason65 is offline   Reply With Quote
Old 02-27-2009, 01:48 PM   #4
jason65
Registerd User
jason65's Avatar
Re: 64 lwb frame
Here dude, Mabey this will help.http://67-72chevytrucks.com/vboard/s....php?p=3161958
Old 02-27-2009, 01:52 PM   #5
jason65
Registerd User
jason65's Avatar
Re: 64 lwb frame
Here is another.http://67-72chevytrucks.com/vboard/s....php?p=3126952
Old 02-27-2009, 02:14 PM   #6
ruffrida2005
Re: 64 lwb frame
Thanks Jason. I've been following your thread, and the truck is looking good! I was just too lazy to look it up for myself, and my internet is really slow.
Paul
Old 02-27-2009, 06:58 PM   #7
kizer
Its Deja Vu time again
kizer's Avatar
Re: 64 lwb frame
Stay safe over their man.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 02-28-2009, 12:32 AM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Re: 64 lwb frame
That air tank should fit between the frame rails. I think you may have to screw with some stuff but you should be able to wedge it all in. Its a little different than a pick-up....but here it is. On the right you can just see the corner of the gas tank. Its tite, but it fits. If you can hang your valves off the tank it will take less space, I made a rack for my valves.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-28-2009, 05:03 AM   #9
ruffrida2005
Re: 64 lwb frame
Protrash how low does your tank hang from the bottom part of the rails? I will be laying frame so putting it ontop of the frame is no problem, my valves are either gonna be on the tank or close to the bag? does the front of your drop pretty quick with the valves being that far? I'll be using 3/8 to drop and 1/2 fill.
Paul
Old 03-01-2009, 11:51 PM   #10
protrash64
protrash64's Avatar
Re: 64 lwb frame
I didnt exactly spit it out in my original post, but you're looking at a 'burb. Gives you an idea of whats up anyway.
The tank hangs down about 5". I have 1/2" line and the whole truck drops like a rock; I have to be careful. The front fills quickly once I have good pressure and the hose is filled. I would use 3/8's if I did it over. I used pipe plugs on the exhaust side of the valves and drilled a 3/16ths hole in them and Im glad I didnt do the holes any larger.
I would suggest mounting the valves to the tank if you have a bunch of ports, it may save you some fittings which are expensive. There are enough things to nickel and dime you on these set-ups.
