Old 02-27-2009, 02:00 PM   #1
b00sted
b00sted's Avatar
Picked up my Rearend
3.55 Posi, Disk Brakes and super strong 8.8....
all for $150 from the local scrap yard and they pulled it and loaded it.. Nothing cut except for a sensor wire on top which I would never use annyways.. The ebrake cables are still in tact and not cut..
What a great deal! Funny thing is I got the rearend before the truck,.... Thanks to mother nature...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 02-27-2009, 03:30 PM   #2
blackdiesel
blackdiesel's Avatar
Re: Picked up my Rearend
Go back and get your rear sway bar, and the drive shaft. great buy
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 02-27-2009, 03:37 PM   #3
b00sted
b00sted's Avatar
dont want the sway bar because it bolts to the body.. I am going to lay the frame with this one... And spicer makes the adapter for the yoke...
Old 02-27-2009, 05:09 PM   #4
robin58
I'd still reconsider saying no to a swaybar. BTW are you sure you're going to lay frame or are you going to lay runningboard.
robin58 is offline   Reply With Quote
Old 02-27-2009, 05:24 PM   #5
b00sted
b00sted's Avatar
Ok you got me there... I gues sthe boards will hit first....
Old 02-27-2009, 05:33 PM   #6
robin58
there ya go
From a safety point of view though it's something to remember. If something fails with your bag system using a stock frame, body damage obviously will occur.
Old 02-27-2009, 05:44 PM   #7
b00sted
b00sted's Avatar
Ya I thought about that.. But Classic truck parts has about anything I need so it gots to get low.....LOL
Old 02-27-2009, 10:35 PM   #8
stan3018
waoooo cant beat that price ..nice rear end ,rear disk brakes and lots of power ...cant wet to see more pics....good luck
stan3018 is offline   Reply With Quote
Old 02-27-2009, 10:55 PM   #9
entourageguy
Yellow truck club
entourageguy's Avatar
Sound like a great deal.
Whats it going into? oh I see now 53 3100
What's it out of?
Give us the width measurement?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-27-2009, 11:11 PM   #10
mrh33916
Project '67 454
mrh33916's Avatar
I have a few questions about this swap if yall don't mind answering them,
What is the difference in the width of the 8.8 and the 67-72 12 bolt?
Is the lug pattern the same?
What about the e-brake connection?
And lastly if you have power front disc/rear drum brakes do you need to change the proportioning valve with the addition of the rear discs on the 8.8?
Thanks in advance for the input,
mrh33916 is offline   Reply With Quote
Old 02-28-2009, 08:27 AM   #11
MOTHERTRUCKERS
entourageguy What is the hubgarage? A customer of mine sent me a private invitation to join and i did but??
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-28-2009, 12:16 PM   #12
Silveradobs
For specs on the Explorer 8.8 see
http://www.therangerstation.com/tech...plorer8_8.html
Silveradobs is offline   Reply With Quote
Old 02-28-2009, 06:19 PM   #13
Zach_H
I was wondering the exact same thing. Everything I looked at says the bolt pattern is 5x114? If that's the case, then it would be a mis-match for the s10 swap correct?
Zach_H is offline   Reply With Quote
Old 02-28-2009, 07:57 PM   #14
b00sted
b00sted's Avatar
The only thing is you have to run ford rear wheels.. No biggie at all..
Old 02-28-2009, 08:27 PM   #15
blackdiesel
5 on 4 1/2 (ford dodge) bolt patern, But if your doing a m II or the dodge dakota front in. then it's just right. They also make steele and ralley wheels that have both 5x4 1/2 and 5x 4 3/4 bolt patern on them. I sub framed my 38 coupe with a 69 f-body and have the 8.8 rear with the steele wheels painted lime green with babys and beauties and hot rod black.. I think it's cool
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 02-28-2009, 09:14 PM   #16
stan3018
The only thing is you have to run ford rear wheels.. No biggie at all.that is so funny /////r u going to put your big tires in the front? its a show car...igot the same rear end and when is time to get rims im going to get ford pattern to the back 20x10 and 18x7 for the front if i get a flat just call the flat bed and that it.......
Old 02-28-2009, 09:32 PM   #17
Kabwe
Certified Car Nut
Kabwe's Avatar
You don't have to you can have your axles and rotors redrilled. I have a 9 inch in my 55 210 with redrilled axles and rotors. It all depends on what you really want. For every action theres a reaction. It was important to me to stay with the Chevy bolt pattern because of my Chevy 210 front end. But with a mustang two you can buy rotors either way. I just wanted you to know you still have a choice. By the way its easy to take the axles out that rearend it's a c-clip rearend.
Kabwe is offline   Reply With Quote
Old 02-28-2009, 09:36 PM   #18
stan3018
why redrilled .? r u going to use ur wide tire in the front?
Old 02-28-2009, 09:51 PM   #19
Kabwe
Certified Car Nut
Kabwe's Avatar
It has nothing to do with the front. I have 18x7 up front. I have 55 210 (not talking about my truck) with a 9 inch. The front suspension is not changed other than disc brakes they came with IFS. I wanted the bolt pattern to match so I had my rearend axles and rotors redrilled to match the front. In other words I had the 9 inch Ford redrilled to be able to install Chevy wheels.
Old 03-02-2009, 06:38 PM   #20
chuckmc8
It's alsways something.....
chuckmc8's Avatar
subbin in here
chuckmc8 is offline   Reply With Quote
