![]() Join Date: Feb 2009
front suspension swap
i am about to swap over a 87 front suspension over to my 68 truck i was wondering if drop spindles from a 88-91 truck were the same i thought i read in this forum that they were but i cant find that now just wondering thanks
Re: front suspension swap
88-98 spindles are different.
thanks scoti for the info
Hi
88-91 suburban would be the same. As 7387 truck, but there is 2 different kinds of spindle for 73-87 trucks, one spindle uses 1.25" thick rotors and the other is 1" thick rotors. |
#5 | ||
Correct 88-98 trucks also had 2 different spindles, and 92-2000(early) were the same as 88-98 trucks.
