Old 02-27-2009, 03:49 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
where is the horn in my '78?
hey guys, my horn quit working and i'm trying to find the "honker" under my hood.
where is it?
are there any common problems with the horns on these trucks?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-27-2009, 04:22 PM   #2
willett
willett's Avatar
Re: where is the horn in my '78?
okay so i pulled the horn button assembly apart and i can make an arc between the sprung pin and the body ground.
i'm assuming that this is good because it means that i am getting power up the colum?
*okay i put a multimeter on and i'm getting 13 v at the colum
Old 02-27-2009, 04:46 PM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
the horn is behind the grille next to headlights
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-27-2009, 04:46 PM   #4
menace121978
menace121978's Avatar
there is 2 i believe. both in the grille under the hood latch. one on each side. maybe the wire(s) just came unclipped?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 02-27-2009, 04:47 PM   #5
menace121978
nice!LOL just a few seconds behind
"Dennis the Menace"
Old 02-27-2009, 05:12 PM   #6
willett
willett's Avatar
what color is the lead that powers the horn?
Old 02-27-2009, 05:32 PM   #7
flamingbig10
6.0 powered square
that happens on here all the timeI think wire is dark green, if you open the hood on the driver side its routed by the headlight through the radiator support if I remember right
Aaron
Old 02-27-2009, 05:39 PM   #8
willett
willett's Avatar
okay thanks guys i found it.
its not quite the shape i was looking for!
now where is the horn relay hidden?
Old 02-27-2009, 05:45 PM   #9
flamingbig10
6.0 powered square
Its a few inches above or side of the fuse panel, don't remember since I have a universal wiring harness
Aaron
Old 02-28-2009, 05:42 AM   #10
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Yeah it's above the fuse box.
Most of the time it's the horn ring in the column, but I've had a few of those horns go bad on me too.
heavychevy79 is offline   Reply With Quote
Old 02-28-2009, 10:28 PM   #11
willett
willett's Avatar
i still have power at the colum,
i have tried to arc with a screwdriver but nothing, so i am hoping that it is the relay
Old 03-02-2009, 04:33 AM   #12
heavychevy79
Cheyenne Super
Put a test light on the horn wire and get someone to push the button.
I'll bet the horn is bad.
Old 03-02-2009, 04:43 PM   #13
willett
willett's Avatar
thanks guys,
after f*cking around for a few hours it turns out it was just the relay.
d'oh!
