Old 02-27-2009, 05:23 PM   #1
Blazer Eagle
shackle flip
hey all, i have found a shackleflip for sale with 6.5 inch shackles, my question is how much lift will this net? im using my stock springs from 74 so they have a little sag, so if it gives me a 6 inch lift and they sag an inch then that gives me 5 which means i can ditch the add-a-leaf and have a raised back stance, if it in fact will give me a 6 inch lift, i think i heard that you add half the shackle length to your lift, but i dont know where the shackle flip is compared to stock, oh, its the diy4x version
Blazer Eagle is offline   Reply With Quote
Old 02-27-2009, 07:50 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: shackle flip
I think this might get a better response in the 4x4 forum. Not so many 4wd experts in here...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-27-2009, 09:45 PM   #3
drbyrdman
drbyrdman's Avatar
Re: shackle flip
around 4".
drbyrdman is offline   Reply With Quote
Old 02-28-2009, 02:39 PM   #4
famous4130
Re: shackle flip
well you will most likely pick up 5-7 inches of lift because just be flipping the shackle itself you can pick up a couple inches. but sometimes depending on the shackle design even if its a 6.5 inch shackle you might only get three inches out of it.
You WILL however, notice a a pretty big difference in how your truck flexes out and its body roll. if you do a lot of off roading then i would say do it, if this is your daily driver i would say get a sway bar up front if you don;t already have one.
My vehicles so far....
1967 GMC 7500, 1967 INTERNATIONAL TRAVELALL, 1977 K5 BLAZER, 1977 C10, 1977 SUBURBAN 4X4, 1985 K5 DIESEL BLAZER, 1989 JEEP CHEROKEE 4X4, 1989 SUBURBAN 4X4, 1991 383 CHEVY SILVERADO 4X4, 1994 TOYOTA 4X4, 1996 TOYOTA TACOMA 4X4, 1999 R6, 2006 GSXR 1000, 2008 GSXR 600
and i THINK thats all... huh, now that i wrote it down that looks like a LOT for a twenty year old.
famous4130 is offline   Reply With Quote
Old 02-28-2009, 08:16 PM   #5
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
Re: shackle flip
you'll get around 4" of lift with a shackle flip and 1" of lift with the longer shackle. you could get more lift out of the shackle depending on the angle of it, but you want to have the shackle leaning 35-45* backwards (ex: \ ). if the shackle is more straight up and sown it'll be more lift, but ride horrible and could reverse if it flexes at all.
bmeredith is offline   Reply With Quote
Old 03-01-2009, 03:19 PM   #6
Blazer Eagle
Re: shackle flip
does a shackle flip have more body roll than an all spring 4inch lift? and i do have a swaybar up front
Old 03-03-2009, 03:36 PM   #7
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
Re: shackle flip
what are your plans for this truck. daily driver, weekend warrior, mudding machine, rock legend... if you can tell me what you want to do with your truck i can help you out a little more.
the shackle flip won't make any more body roll than stock
Old 03-03-2009, 04:43 PM   #8
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
I like that, "Rock Legend!"
A flip does raise your center of gravity and will allow body roll to be more noticeable. I just did a 4" ORD flip on my K5, and I would not want to drive much on the streets (especially higher speeds) without the front sway bar connected and with good bushings.
Are the new shackles cross-tied? If they are from DIY then they probably are...
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 03-04-2009, 01:10 AM   #9
Blazer Eagle
Re: shackle flip
it will probably be mostly a daily driver with some moderate trails and some moderate mud, the extreme stuff just isnt for this rig, im going to build a purpose built one for those things
i want a 4 inch lift, so my main options are spring or shackle flip, so my questions is does the shackle flip have more body roll than a spring lift would, i wont be doing anything super serious so a spring lift would be fine
Old 03-04-2009, 01:11 AM   #10
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
Re: shackle flip
it must just be personal pref. because i've smashed my truck around town hard for years w/o a swaybar and have never felt uncomfortable. that'll change when i put my 52" in front but until then i won't think twice about it. those superlift 4" lift front springs are real stiff and keep my truck under control pretty well. and that stock sway bar limited flex so bad i ditched it as soon as i could
Old 03-04-2009, 01:53 PM   #11
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
Well, I have the ORD sway bar disconnect, so I don't have to worry about flex off road, and I don't wallow around when I'm on the pavement doing 75 either.
I suppose that if I still lived in a small town it would be cool, but here in Phoenix traffic it was a bit sketchy.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-04-2009, 02:01 PM   #12
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-04-2009, 03:16 PM   #13
FormerMember
Re: shackle flip
Lift shackles give you half the lift of the length of the shackle over stock shackles.
Stock shackle = 4" (hypothetically)
6" shackle is 1" lift, as it only drops (if the shackle is flipped, I.E. pointing down) one end of the spring.
FormerMember is offline   Reply With Quote
Old 03-04-2009, 08:10 PM   #14
BIG HEAD
Re: shackle flip
It will shorten your wheel base. The tire will not be in the center of wheel well. It will be closer to front.
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393
BIG HEAD is offline   Reply With Quote
Old 03-04-2009, 08:14 PM   #15
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
Meh, the arc that the rear spring is on, moves the axle forward a negligible amount... visually it is not detectable IMHO.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-04-2009, 08:19 PM   #16
FormerMember
Re: shackle flip
Which is also why people use zero rate spring blocks to move the axle back.
Old 03-04-2009, 10:47 PM   #17
Blazer Eagle
Re: shackle flip
yeah i have thought about using a zero rate, but im not sure which lift i should get, with a swaybar, is there any difference in bodyroll between a spring lift or an shackle flip?
Old 03-05-2009, 12:24 AM   #18
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
Re: shackle flip
the lift springs will be stiffer but your COG will be the same either way. so the shackle flip might have a little more roll
Old 03-05-2009, 08:07 AM   #19
BIG HEAD
Re: shackle flip
It is not so noticeable with a two inch flip. But very detectable with six. I'll get pictures this week end. I understand completely that some times the shackle flip is used to get more wheel travel in certain applications. But in other applications it is used for more lift. That is the part I don't get, because by the time you spend nearly $190.00 on a flip kit, $60 on new shackles, and what ever zero rate blocks cost, plus shipping. You are well over the new price of two lift springs.
If I was looking for a softer ride w/lift I would either a: lower both spring hangers uqually or b: get a set of lift springs remove the bottom 2 or 3 springs in the pack and then install a twisting shackle.
Old 03-05-2009, 01:34 PM   #20
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
Well I did a four inch flip, had no need for zero rates, virtually the same ride as stock, increased flexability and saved about $220 compared to new getting new springs.
YMMV
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-05-2009, 02:34 PM   #21
BIG HEAD
Re: shackle flip
Originally Posted by oilbrnr View Post
well i did a four inch flip, had no need for zero rates, virtually the same ride as stock, increased flexability and saved about $220 compared to new getting new springs.
Ymmv
it sounds as though things worked out well for you. Did you make your flip kit or buy one (what brand)?
Old 04-02-2009, 09:02 PM   #22
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
ORD made the brackets. DIY4X would also be equivelent.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 04-06-2009, 02:49 PM   #23
BIG HEAD
Re: shackle flip
Like I said $189.00 for ORD 4 inch flip kit, plus shipping. Two hundred twenty for springs at local parts house. So you did not save $220.00.
Old 04-06-2009, 04:38 PM   #24
Oilbrnr
Oilbrnr's Avatar
Re: shackle flip
I have no idea if I could have gotten rear springs from a local parts house with a 4" increase in ride height for $220. Tuff Country gets ~$400 for a pair, so that is what I'm comparing too.
You don't like non-homebrewed flips, so be it. Some of us do not have the resources to fab up whatever we want like you apparently do. So be it.
Like I mentioned earlier, YMMV.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
