Old 02-27-2009, 07:05 PM   #1
caminokid
Chevy nut
caminokid's Avatar
Tilt Telescopic Streering.
I gutted out a 66 Olds 98. I took alot of good parts off it. It even had a big block 425 Super Rocket in it.
I took the column out not knowing it had telescopic on it. I was taking the shifter collar off it, when I went to take the steering wheel off, I couldnt get the horn ring off. I grabbed the center and twisted it and out it came....telescopic! So I got everything on...the seal up around the dash....the floor board seal and collar. I am putting it in the steeper tomorrow to test fit it. I will post pics as I am doing the job. If this works out like I think it will....I think we will have a few more options for tilt wheels out of big GM cars before 69.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 02-28-2009, 04:10 PM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: Tilt Telescopic Streering.
As promised pics. I had to modify two brackets. The wiring wasnt a problem. I collapsed the out column. The rod that goe from the column to the steering box. I had to cut the auto shifter collar off so I could set the column in.
Heres some pics.
Its not done. I got alittle too cold out there. I had to tuck the wiring under the dash...mount the turn signal switch. Put the truck back together. But this is and idea of what it takes to put a big GM car column in a 67 to 72 Chevy truck. I also am going to take a piece of aluminum to cover the section right before the dash.
Old 02-28-2009, 05:04 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
That's pretty cool, good job!
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-28-2009, 05:56 PM   #4
OARNGESI
OARNGESI's Avatar
Really cool did you check what that column was worth before i know ones from an impala is worth some nice money
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-28-2009, 07:45 PM   #5
caminokid
Chevy nut
caminokid's Avatar
It could have been worth a mint...But I wanted to do this. Its not the worth or money I could have gotten. I believe this being able to be done is worth more then the money.
Besides...the steering wheel is really cool!
Old 02-28-2009, 07:46 PM   #6
david jobs
Maybe someday will come
david jobs's Avatar
Might have to go on another steering colomn search-haven't seen any in trucks or vans in my area
David
1971 C10 Soon to be DD
1988 27' Class C Tioga MH
2001 Fat Boy
2003 Gmc Envoy-Wifes ride
1992 Ford Ranger-DD for now
david jobs is offline   Reply With Quote
Old 02-28-2009, 08:24 PM   #7
caminokid
Chevy nut
caminokid's Avatar
Re: Tilt Telescopic Steering.
Originally Posted by david jobs View Post
Might have to go on another steering column search-haven't seen any in trucks or vans in my area
Thats why I measured this one. Yeah I had to money the buy a new column...tilt only. So this was a quick not so expensive experiment that came out good.
Old 02-28-2009, 09:18 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
I have one out of a '67 Toronado that I have been saving. I might throw it in one of my trucks!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-28-2009, 09:22 PM   #9
caminokid
Chevy nut
caminokid's Avatar
You will find it is worth it. The cable that goes down to the turn signal switch...if you have a manual trans....unmount it. I am looking for a spot to mount it under the dash. I need to find a Chevy emblem for the center button. I really am pleased with my idea. I wasnt sure it would work...but it works. Use the plug off an old truck column and the wires are color coded.
Old 02-28-2009, 09:26 PM   #10
Boog
laying low
Boog's Avatar
Ah, affordable alternatives. Harder to find these days but it looks good in there.
Also if that wheel doesn't do it for you many other GM wheels will bolt up to that column as most have the same shaft diameter and spline count.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-28-2009, 09:37 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
oh man you gotta cut the top and bottom off of that wheel, well it would look cool in a rat rod truck.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-28-2009, 09:41 PM   #12
project 67 sub
project 67 sub's Avatar
but if you take off and replace the steering wheel wouldnt it delete the telescopic part like on the caddy steering cloumns? a buddy took his off and the telescopic part was part of the steering wheel.
project 67 sub is offline   Reply With Quote
Old 02-28-2009, 09:46 PM   #13
caminokid
Chevy nut
caminokid's Avatar
Can we say Knight Rider? That wheel is perfect. I could see me doing that to that old wheel. It just looks cool along with the nostalgic touch of yesteryear.
Old 02-28-2009, 09:47 PM   #14
caminokid
Chevy nut
caminokid's Avatar
Originally Posted by project 67 sub View Post
but if you take off and replace the steering wheel wouldnt it delete the telescopic part like on the caddy steering columns? a buddy took his off and the telescopic part was part of the steering wheel.
Yeah there is no way of getting rid of the wheel for another. I really like the fact of telescopic. Makes this 69 one of a kind.
The center...you twist it loose and it works the telescopic. We may see and uprise in old caddys losing the columns now!
Old 02-28-2009, 09:58 PM   #15
project 67 sub
yah i wouldnt be suprised about the caddy column thing to, cuz it would probably work. oh yah and it was a 73 caddy, but my other buddy has a 70 caddy that has a telescopic tilt to. not sure what year they started though, probably in the learly 60's
Old 02-28-2009, 10:42 PM   #16
Boog
laying low
Boog's Avatar
Ah ok. I did not know the wheel was a part of the 'scopic function.
Boog
primer is finer
Old 03-01-2009, 10:27 AM   #17
caminokid
Chevy nut
caminokid's Avatar
yah i wouldnt be surprised about the caddy column thing to, cuz it would probably work. oh yah and it was a 73 caddy, but my other buddy has a 70 caddy that has a telescopic tilt to. not sure what year they started though, probably in the early 60's
I had a 64 Coupe De Ville that had the tilt/tele option.
Old 03-01-2009, 11:28 AM   #18
truckpoorpackrat
That looks great. Here are some pictures of mine, work in progress. Top piece mounts behind steering wheel. I cut the center off the steering wheel & used it to mount a aftermarket wheel. Same bolt pattern just different size bolts. Funny thing I cant remember what year the column is
truckpoorpackrat is offline   Reply With Quote
Old 03-01-2009, 12:35 PM   #19
caminokid
Chevy nut
caminokid's Avatar
Its a 69 and up...but it almost looks like its going to set the wheel into your chest. Even though I collapsed the shaft to get it where I wanted it....If I extend the telescopic its in my chest. I cut the auto shifter collar off so I could put the column in towards the dash. Not knocking it...I just thinks it going to lay it into your chest.
Old 03-01-2009, 02:19 PM   #20
truckpoorpackrat
You would be correct, except I'm 5'11 140lb. Planning on putting in a seat out of a 2005 pickup in it. I'll take pictures when I'm done. I have another 69 with factory seat/wheel no tilt, not enough room for my legs, main reason i never drive it.
Old 03-01-2009, 06:11 PM   #21
caminokid
Chevy nut
caminokid's Avatar
I agree on the no leg room. I am also 5"11'...but 240. My leg would hit the steering wheel everytime I went to get out of the truck. it has drove me nuts. The steering wheel was one my brother picked up at the junkyard and it was painted red. So i always got a red mark across my jeans.
Old 03-03-2009, 05:02 PM   #22
caminokid
Chevy nut
caminokid's Avatar
Does anyone know the best paint for the column and how do I dye the steering wheel?
Old 03-03-2009, 08:03 PM   #23
mr48chev
mr48chev's Avatar
I think most guys paint the columns with regular automotive paint in the proper color to match the interior of the rig.
I'm not sure on the wheel it's self but I think a few searches on steering wheel restoration will bring up answers.
There are horn kits available to put custom wheels on some tit tel columns but they seem hard to find and usually are for Corvettes. I have one out of a 76 Seville that isn't huge and should work in a truck like this. Now you have me started on another project as if I need another one.
I like that Olds wheel just the way it is without modifications outside of color and maybe a Chevrolet emblem to replace or cover the Olds emblem unless of course you run the 425 and then I think it would be more than proper.
Old 03-03-2009, 08:20 PM   #24
GOPAPA
GOPAPA's Avatar
good job Kid,, I would like one of those myself .on my truck .I had one but sold it ..it was hooked to my Vette .LOL sure amazed people when they seen me screw the horn button and pull the wheel towards me just before driving off.
Now I can say I know a guy who put a teleoscopic steering wheel in one of our old trucks..
GOPAPA is offline   Reply With Quote
Old 03-03-2009, 09:00 PM   #25
caminokid
Chevy nut
caminokid's Avatar
I love the wheel. Dont want to change it at all. I want the column and wheel black. The button for sure needs the Chevy emblem in the middle.
