02-27-2009, 07:20 PM | #1 |
Front axle question
Guys, my '72 Blazer has a broken passenger side axle shaft. What I need to know is whats interchangeable with it, do pickups have the same length shaft? What about newer year trucks?
Also, I know the 10 Bolt and Dana 44 are somewhat similar, will a shaft from that work or does it have to be from a 44? I'm dying to get this truck going again. |
02-27-2009, 07:24 PM | #2 |
Re: Front axle question
the axles are interchangeable on open knuckle 44's between pickups and blazers. i believe that the only difference in 10 bolt axles is that the outer stub is a different length but i'm not sure on that one
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
02-27-2009, 09:59 PM | #3 |
On the 44's are they the same up until they changed to the 10 bolts in the mid 80's?
02-27-2009, 10:09 PM | #4 |
Future TOTM Winner
Like CPNEJR said, all of the open nuckle chevy D44 should work, but I believe they switched to the 10 bolt in 76 or so, not 80's.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
02-28-2009, 10:49 AM | #5 |
The outers are the same. It is the inner that is different on a 10 bolt. The 72 and earlyier trucks use a smaller u-joint than the later. Get yourself a 73-79 Dana 44 front.
