02-27-2009, 09:10 PM | #1 |
Any diffence in Cabs from 67 to 70?
I have an all 67 SWB with a small window. I found a big window 70 cab. Will the 70 cab fit my 67 frame? Will a 70 cab look different than my 67 cab (other than the back window)? Any differences at all?
02-27-2009, 09:12 PM | #2 |
Re: Any diffence in Cabs from 67 to 70?
The ignition switch opening is larger on the '70.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
02-27-2009, 09:53 PM | #3 |
Is that the only difference? So it will still look like a 67 (other than the 70 ingition switch). I thought that the back of the cabs were curved a little different or something.
02-27-2009, 09:56 PM | #4 |
its all about the +6 inches
the shape of the cab is the same
The ignition switch as stated, the fuse box mounts sideways... I think that's about it. Very minor things. |
02-27-2009, 10:02 PM | #5 |
I just learned from another post that the ebrakes or different. Thanks for the input guys.
02-28-2009, 01:04 PM | #6 |
ignition switch ,fuse box e brake,air vents are a little different rearveiw mirror mount and the way the hook for visors mount was alittle different on mine dash behind gauge bezel and im sure there's other small things to but rather easy to overcome all of it with a little thought
02-28-2009, 02:58 PM | #7 |
the air vents in the door jamb started in 71, and the mirror mount was chainged in 71 also.
Good point on the parking brake setup |
02-28-2009, 03:29 PM | #8 |
ashtray is also a 67 only unit.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
02-28-2009, 07:11 PM | #9 |
the kick panel air vents are different on mine
