02-28-2009, 11:33 AM | #1 |
PITbut
Loosing air pressure on an airbag system.(updated)
UPDATE 3/5I have 4 bags. Is it common to have an air pressure drop over a night of sitting??? With the 8 valves and all the lines, im going crazy trying to keep it 100% air tight...
02-28-2009, 12:13 PM | #2 |
67-72 parts collector,…
Re: Losing air pressure on an airbag system.
How much air are you talking about.
I try to use DOT fittings and a good thread sealant. (like Loctite 545 hydraulic thread sealant) No leaks here.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-28-2009 at 12:14 PM. |
02-28-2009, 12:17 PM | #3 | |
PITbut
What im going to do tonight is air up the whole system to 90psi on all 4 bags and just sit there with some soapy water and see where the bubbles are.. The ONLY problem is that the top of the airbag fitting isnt accesable unless i unbolt the top mount plate. ahaha.. Here is how i have my airbag valves set up. [IMG]http://www.*****************/files/how_to/wire-diagrams/valveassembly.gif[/IMG] |
02-28-2009, 12:48 PM | #4 |
02-28-2009, 12:49 PM | #5 |
PITbut
02-28-2009, 03:32 PM | #6 |
I've had mine at 80 psi for weeks. You must have a leak somewhere.
02-28-2009, 04:29 PM | #7 |
PITbut
02-28-2009, 09:50 PM | #8 |
Good luck with the tests. Doesn't sound like too big of a leak, which is good, but sucks at the same time. Should be worth it in the end though.
03-01-2009, 01:40 PM | #9 | |
PITbut
start front = 60 start rear = 75 tank = 120 BRB Ok, all bags stayed the same. The tank dropped down to 80.... There are 7 ports on the bag, i know i have a bad petcock valve that might leak a TINNNYY tiny bit, but i didnt check to see iff the pressure switch was not leaking. Glad the bags didnt leak. Will let ya know what else is leaking on the tank... |
03-01-2009, 03:03 PM | #10 | |
Glad to hear its not at the bags and is a relatively easy to get at fix.
03-01-2009, 05:07 PM | #11 |
Do you have check valves?
1981 - C-10 SCSB Planning on putting this thing on it's rocker! |
03-01-2009, 06:58 PM | #12 |
It might not even be the tank. If you have Viair compressors, might be the check valves on those. Those are notorious for leaking. You might have air from the tank leaking out your compressor.
03-01-2009, 07:47 PM | #13 |
werd. i'm gonna run 6 check valves. 4 for the bags 2 for the viair compressors.
03-01-2009, 09:24 PM | #14 | |
PITbut
Check valves?? No. I have two for my compressors. One on each. But thats it..
What are you using the check valves for? Where do those go and you have any pics??? |
03-06-2009, 12:21 AM | #15 | |
PITbut
I have the airbag valves setup like the picture up above, but i have NO idea whats going on... Anyone? Why would losing the air pressure in the tank, cause the bags to lower. ?? |
03-06-2009, 12:39 AM | #16 |
PITbut
I dont know if im making myself clear. SMC valves. setup like this.
[IMG]http://www.*****************/files/how_to/wire-diagrams/valveassembly.gif[/IMG] Airbags at 80psi. Tank at 120. No issues. Say i drop the air in the tank down to 70psi or so, the bags will lower also. As the air is 100 percent out of the tank, the bags are empty also... This right? The valves need pressure from the tank??? |
03-06-2009, 12:59 AM | #17 |
Re: Loosing air pressure on an airbag system.
I have my valves setup the same way and without pressure behind the valves(from the tank) the bags will deflate. The tank psi always needs to be greater than the psi in any given bag.
Jay Last edited by Chevy4Life; 03-06-2009 at 01:00 AM. |
03-06-2009, 01:05 AM | #18 |
PITbut
Ok. awesome. thats what im gathering. So, is that where check valves come into play??? You have any check valves on your ride?
03-06-2009, 01:13 AM | #19 | |
Jay Last edited by Chevy4Life; 03-06-2009 at 01:21 AM. |
03-06-2009, 01:20 AM | #20 | |
PITbut
Thanks for the time and responses. |
03-06-2009, 08:26 AM | #21 | |
03-08-2009, 06:05 PM | #22 |
Too many projects
If you're looking to use check valves, I bought spare leader hoses from suicide doors for like $15 each (cheapest check valves I could find) and those feed from my tank to the valves and also are braided stainless to eliminate the DOT tubing. I also run hydraulic line from the valves to the bags. I drove 250 miles with an empty tank and didn't drop a pound in the bags (digital gauge). I'll get a pic here in a bit...
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
03-08-2009, 08:53 PM | #23 |
Check kplinks or waylayed for check valves too...
