Old 02-28-2009, 11:54 AM   #1
rigon4
rigon4's Avatar
drive shaft help
Ok i think the drive shaft is to long in my 85 short step. It has a 502 with a th400 but its had three trans in it in under 10k it keeps wipping out the tail shaft bushing. I just bought it and i only want to put one trans in it. So does anyone know how long the shaft should be??
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 02-28-2009, 06:44 PM   #2
1984 swb chevy
1984 swb chevy's Avatar
Re: drive shaft help
I dont know how long it should be but I do know that your yoke should be out of the seal about an inch. If it is to long the yoke will be against the seal. if it is to short it will leak fluid under hard acceleration. I hope this helps
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
Old 02-28-2009, 09:50 PM   #3
Rosscup
i have a 77 short box 4x4 with a TH350 and a NP208 and its drive line is 43.25 inches long but thats a 4x4 so maybe that will give you a ball park
Rosscup is offline   Reply With Quote
Old 03-01-2009, 04:15 AM   #4
rigon4
rigon4's Avatar
with the truck on the lift i had a 1/4 inch to slide the yoke in to get to drop out the rear u joint so thats why i think its to long
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 03-01-2009, 04:55 AM   #5
78 Chevyrado
I'm not sure how much, but from what you say it is too short. 1/4 inch is not enough. I'd think it would be like 1-1.5 inches or so, correct me if i'm wrong guys.
78 Chevyrado is offline   Reply With Quote
Old 03-01-2009, 08:39 AM   #6
grinch4om
dang its hot
grinch4om's Avatar
seat the yoke all the way in, pull out 1-1.5 inches, then you can look at how close the rear joint is to the saddles on the rear end...support the truck with jack stands on the suspension when you do this
grinch4om is offline   Reply With Quote
Old 03-01-2009, 10:49 AM   #7
rigon4
rigon4's Avatar
the local drive shaft shop wants a measurement from seal to center of u joint with it on the ground. I dropped the trans pan and its junk there is chunks of aluminum.
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 03-01-2009, 06:40 PM   #8
Damien
Damien's Avatar
QUOTE=78 Chevyrado;3173015]I'm not sure how much, but from what you say it is too short. 1/4 inch is not enough. I'd think it would be like 1-1.5 inches or so, correct me if i'm wrong guys.[/QUOTE]
The drive shaft is too long. I'm sure you just typed it wrong.
I would crawl under the truck and measure the way your shop wants. That is the only way you can be 100% sure you have the right lenth driveshaft.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-01-2009, 07:30 PM   #9
rigon4
rigon4's Avatar
did gm make a short box with a big block and a th400 with a one piece drive shaft if so what year?
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 03-02-2009, 10:30 AM   #10
Cherub
Cherub's Avatar
+1 on getting the shop a correct measurment.
Cherub is offline   Reply With Quote
