Old 02-28-2009, 12:00 PM   #1
Redline
Redline's Avatar
VIN where to find on the Frame???
Can some one help me find where the VIN is on the frame?? The truck I bought has a C20 cab, but dually one ton frame.... I would like to know more about the frame but can until I know what it is. Thanks!!
Redline
Redline is offline   Reply With Quote
Old 02-28-2009, 12:16 PM   #2
Redline
Redline's Avatar
Re: VIV where to find on the Frame???
Sorry for posting this, I just found another post where it tell about about my exact question..... not sure how to delete my post though
Old 02-28-2009, 03:54 PM   #3
TimE
Hey Y'all!!
TimE's Avatar
Honestly, looking at the pics that appears to be a standard 1/2 or 3/4 ton frame with channel welded to the top part of the frame to beef it up. I may be wrong, but my guess is that someone wanted a dually and swapped in the front suspension and the rearend and then beefed the frame up to match.
On second look, does the extra frame height end at the cab? I'm thinking that may actually be part of the dually frame that the suspension came from, cut and welded to the top of the original frame, if so.
Just my $.02.
Good luck with it!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-28-2009, 03:59 PM   #4
jason65
Registerd User
jason65's Avatar
You gotta be a site supporter to delete things.
jason65 is offline   Reply With Quote
Old 03-01-2009, 01:40 AM   #5
Captainfab
60-66 Nut
Re: VIN where to find on the Frame???
That looks to me like it was not originally a 1 ton. To my knowledge 1 tons did not come with coil springs in the rear. The shape of the rear of the frame doesn't look like the frame on my '66 C30, it looks more like a C20 frame. The channel on top of the frame that TimE spoke of, was most likely done in the mounting of the bed that was on it.
Let us know what you find out on the frame VIN
Old 03-01-2009, 02:00 AM   #6
collins10672
collins10672's Avatar
the vin on the frame is located at the driver side under the hood on top of the frame rail in front of the motor mount.hope i have been some help.thanks
collins10672 is offline   Reply With Quote
Old 03-01-2009, 06:03 AM   #7
Woogeroo
cool truck.
Welcome...
It takes awhile to find everything around here...
-W
Woogeroo is offline   Reply With Quote
