Old 02-28-2009, 01:12 PM   #1
Woody52
Valve cover gaskets 250 6 cylinder
Good morning to all
Not having to replace a valve cover gasket in a very long time. I have to replace the gasket on my 1969 c-10 250.
The question is do I use RTV on the rubber gasket? Or just use enough to hold it in place.
Woody52 is offline   Reply With Quote
Old 02-28-2009, 02:35 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Valve cover gaskets 250 6 cylinder
I have used rubber gaskets in the past and just didn't care for them. If they work for you, I'd use a minimum amount of sealant. As you mention, just enough to hold them in place.
My preference now is to find some that are cork/rubber mix. On these, I never use sealant on any part that touches the engine block. Makes it easier when you replace the gasket and not have to scrape it off the block surface.
I use Felpro mostly. This site from Jegs explains the differences.
http://www.jegs.com/p/Fel+Pro/746660/10002/-1
68gmsee is offline   Reply With Quote
Old 02-28-2009, 03:30 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
I use a little bit of RTV thinly spread on the valve cover side.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-28-2009, 03:56 PM   #4
El Jay
Gone to greener pastures
I prefer cork, my ownself.
As for holding the gasket in place, I throw the valve cover bolts away, and put studs in the head(s) then set the gasket(s) on the head. Install the valve cover(s), & secure with nuts & washers.
Before I started doing this, I used to put a light coating of bearing grease on the valve cover(s) to hold the gasket in place.
The next time it came to changing the gasket(s) there was no scraping to get the "gunk" off.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
