02-28-2009, 06:31 PM | #1 |
Impala disk brake brackets
HERE ARE THE FIRST ONES I WILL HAVE THEM PERFECTED BY THE END OF THE WEEK AND READY TO SELL IM GOING TO CUT SOME OFF THE CORNERS TO MATCH THE MOUNTING SURFACE AND CLEAN EM UP A LITTLE I CAN MAKE THEM IN STEEL, STAINLESS STEEL, OR TITANIUM IM GOING TO PUT TOGETHER A COMPLETE KIT WITH EVERYTHING YOU WILL NEED TO INSTALL THEM PRICES ARE UP IN THE AIR RITE NOW BUT THEY WILL BE FAIR LET ME KNOW IF YOU ARE INTERESTED THANKS:chevy
UPDATE THE WILL BE READY TO SHIP ON SATURDAY THEY WILL BE $65 SHIPPED IN THE US THANKS GUYS Last edited by weav1; 03-04-2009 at 08:06 PM. |
02-28-2009, 07:00 PM | #2 |
Re: Impala disk brake brackets
Count me in. Just let me know how much and when.
02-28-2009, 10:24 PM | #3 |
Formerly- 1972SuperCheyenne
I am very interested. Thanks for keeping me in the loop through all this. I would like a price on the steel ones with shipping to Apex NC, 27523. Any pics installed. Just wanting to make sure the pad contact is centered on the rotor. Thanks again.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-28-2009, 10:58 PM | #4 |
Also curious to see how this turns out...
02-28-2009, 11:05 PM | #5 |
Count me in for the news when you get it. I know I want discs at some point.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
02-28-2009, 11:35 PM | #6 |
Forgot to ask, how thick is the material you're using?
03-01-2009, 01:28 AM | #7 |
im in
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
03-01-2009, 06:36 AM | #8 |
resident oilfield trash
Does anyone have a parts list so I can figure out how much this would cost to do.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
03-01-2009, 10:54 AM | #9 |
You will need calipers and rotors from a 94-96 Impala SS. Also the rear brake hoses for the same car. Then theres an adapter to adapt your trucks brake hard lines to the Impala brake hose. They are the same as the Caprice or Roadmaster rear discs. I made a template and drilled my rotors myself. They look great and have never had an issue with any of the ones I drilled myself. And lots cheaper than buying them drilled.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 03-01-2009 at 10:56 AM. |
03-01-2009, 11:38 AM | #10 |
72 super i am using the impala rotors also they fit right on i had to clean off the center of the axle real good but no drilling
03-01-2009, 03:11 PM | #11 |
Sorry I should have clarified. I meant cross drilled the rotors. The rotors fit on the axle flange perfectly, no modifications were needed. Didn't mean to confuse anyone.
03-01-2009, 03:39 PM | #12 |
wow how long did that take i just bought the baer decela rotors
03-01-2009, 04:35 PM | #13 |
How much do you want for your brackets. Does 250 sound about right for the whole setup to you guys
03-01-2009, 04:39 PM | #14 |
It took ~20 minutes per rotor. I did all 4 on my drill press. Thay turned out perfect. The rotors cost me $15 each and the calipers were$25 each. I have a wholesale account though so that helps. I have more time than money so I wind up making alot of my own suff rather than buying it.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 03-01-2009 at 04:40 PM. |
03-01-2009, 06:33 PM | #15 |
It's alsways something.....
subbin in
03-01-2009, 06:54 PM | #16 | |
03-01-2009, 07:05 PM | #17 |
By the time I shipped it to you it would cost the same as buying it @ your local auto parts store.
03-01-2009, 07:21 PM | #18 |
im sure it will be less then 250 i havent got all the prices back yet the big down fall is most places want a core on the calipers and brackets napa the kit is $78 and the core is $82 wtf and i guess it depends on what rotors you want i might just sell the brackets and list the part #s for you guys for the rest of the pieces then you can get whatever you want
03-01-2009, 07:38 PM | #19 |
How hard are these axels to get out??? I have to take them out to put on that bracket right?? HOw much do you want for your brackets??
03-01-2009, 07:38 PM | #20 |
If I were you that'd be what I did. You should be too busy to do much else once you get them ready to market...
03-01-2009, 07:56 PM | #21 |
well you can get the axle out in about 5 min i just did it tonight to test fit the brackets you could cut the brackets to slide over the axle and cut off the old backing plates but its not really a big deal some brackets i have seen on here were cut out anyway i will be able to give you guys a price tomorrow night after i get my brackets and calipers i think i willl weld some nuts on on im going to make the hole in the center a little bigger mine wouldnt go on due to the powder coating on the rear end and i dont want to grind it off i dont think it needs to be tight there the four bolts will hold it where it needs to be im thinking around $40-$50 depending on how much i have to do after they are cut how does that sound
03-01-2009, 08:09 PM | #22 |
i am up for some trades also let me know what you got i need a good set of ram horn manifolds edelbrock intake 2401 for later model sm block with center bolt valve covers need chrome center bolt valve covers just let me know i basicly have a complete rolling chassy and a good cab everything else i need
03-01-2009, 08:12 PM | #23 |
I was thinking about cutting them any way. Glad to hear some one else say it first though lol
03-01-2009, 08:14 PM | #24 |
Thats a good looking frame
03-01-2009, 10:02 PM | #25 |
I would love to have a set of the brackets without a nut welded on the back. And you dont need to worry about opening the hole up further on mine either. I dont mind doing all that. I will gladly send you the money through PayPal as soon as you give me the word. Thanks again.
