Old 02-28-2009, 06:53 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
difference between a 78 front axle and a 72?
I have a friend of a friend who has a 1978 4x4 who got T-boned and totaled. He just had his front disc brakes totally re-built, tie rods etc. question I have is will this whole front end fit under a 72? what are the differences?
jcfoote60 is offline   Reply With Quote
Old 02-28-2009, 10:32 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: difference between a 78 front axle and a 72?
Yep, bolts right in. On my 70 K5 I put a 78 3/4 ton's front axle in and the only thing I had to modify was my front brake lines. I had swapped in the 78's power brake booster and needed adapters to mate it to the 70's front hard line and then I found I was going to need adapters to mate the hard line to the 78's rubber brake lines. I ended up just replacing the hard line so I wouldn't have all those adapter fittings.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-01-2009, 10:54 AM   #3
jcfoote60
Active Member
jcfoote60's Avatar
found out the gear ratio is different than mine, will the rear end fit as well?
Old 03-01-2009, 09:55 PM   #4
Mike C
Mike C's Avatar
The rear will fit, but you will have to move the spring mounting pads and shock tabs. I built a jig and put an '86 Suburban 8 lug axle in mine. I kept my Dana 44 and just put the Suburban brakes on it. Mostly because the 10 bolt was a dual shock setup and I didn't want to go there.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
