Old 02-28-2009, 07:33 PM   #1
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Driveshaft...
I shortened my frame from long to short...I have my long bed two piece driveshaft...Will I be able to reuse this or I am going to find another driveshaft? What are my options?
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 02-28-2009, 08:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Driveshaft...
it's 12 inches too long now... since you cut 12 inches out of the middle of the frame.
You can have it shortened, or locate a SWB shaft or shafts.
Old 02-28-2009, 08:55 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Driveshaft...
i would reuse trans yoke and weld yokes and have a one piece made if you can.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-28-2009, 09:02 PM   #4
Longhorn Man
Re: Driveshaft...
if going for a real low stance, 2 piece may be better. A 2 piece is truely a better set up, just takes quality parts to make it worth while.
Old 02-28-2009, 09:02 PM   #5
jholley
jholley's Avatar
Re: Driveshaft...
Unfortunately I've got some experience in this area. As expressed above you can use your front and rear yokes and have a driveshaft custom made. It really isnt that expensive. I paid about $200 to have my driveshaft lengthened two inches. I know that sounds like a lot but really what I'm getting is a new shaft with my front and rear yokes welded to it and balanced.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 02-28-2009, 09:10 PM   #6
the lights
the lights's Avatar
Re: Driveshaft...
I did what you did and I shortened my own drive shaft just took it out of the front that hooks up to the transmission. I split the weld to take out the yoke and shortened then re welded it is worth a shot. I thought it might vibrate at freeway speeds but nothing at all.
the lights is offline   Reply With Quote
Old 02-28-2009, 09:11 PM   #7
brad_man_72
the boat guy
Re: Driveshaft...
a 2 piece is better but when working with 40 year old parts, buying a new slip, stub, and carrier bearing when you could just get a 1 piece shaft made doesnt make alot of sense to me
Old 02-28-2009, 09:17 PM   #8
brad_man_72
the boat guy
Re: Driveshaft...
after working in a driveshaft shop, i highly recommend not doing this yourself. while a diy job is great for getting your truck out of the field, you will be lucky to make a shaft that a pro can fix, most arrent that lucky, and end up spending more money than they were trying to save.
i have seen professional mechanics that couldnt properly install a ujoint if their life depended on it, much less try to weld in an end yoke straight enough to be useable.
Old 02-28-2009, 09:31 PM   #9
the lights
the lights's Avatar
Re: Driveshaft...
I share your concern, it was supposed to be temporary so I could take it to the dmv to be inspectedt, but it worked so good I ended up just leaving it.
