Old 03-01-2009, 06:12 AM   #1
twincam1449
My 1979 C10 Cheyenne
Here you have some pictures from the 1979 Chevrolet C10 Cheyenne I bought one month ago. It has a standard 350ci V8.
twincam1449 is offline   Reply With Quote
Old 03-01-2009, 06:12 AM   #2
twincam1449
Re: My 1979 C10 Cheyenne
Audi TT chairs
Rearwall with side pieces for speakers, covered with imitation leather
Old 03-01-2009, 06:12 AM   #3
twincam1449
Headliner and doorpanel also covered with imitation leather
Doorpanel trim colored black
Old 03-01-2009, 06:25 AM   #4
twincam1449
One problem I have: going over 30 m/h there is a 'humm' in the lower part of the car. With small vibrations.
Putting transmission into neutral still keeps the vibrations.
Sometimes the humm just disappears to return a little later.
Any ideas?
Old 03-01-2009, 06:28 AM   #5
dammitmitchell
the pollock
dammitmitchell's Avatar
pretty pretty pretty trrruck...
seats are an interesting choice....
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-01-2009, 06:29 AM   #6
dammitmitchell
the pollock
i woudl say "tires" for your humming noise..
just my .02 cents
Army vet 02-08
Old 03-01-2009, 08:35 AM   #7
grinch4om
dang its hot
grinch4om's Avatar
rotate tires and try again,if that doesn't move the vibration, pull the driveshaft and look at the u joints
grinch4om is offline   Reply With Quote
Old 03-01-2009, 09:03 AM   #8
twincam1449
I don't think it's the tires.
I mounted new tires and rims this saturday. The humm was even there with the old tires.
Strange is that the humm is not there all the time. Even if it starts, it sometimes disappears.
Grinch4om: the sound seems to come from the driverside.
Old 03-01-2009, 10:55 AM   #9
bigblock73
yeller
bigblock73's Avatar
Maybe a wheel bearing. Take the truck for a drive, when you get home, see if the wheel feels warm...or warmer than the passenger side. That is often a indicator the bearing is bad.
Nice looking truck by the way.
bigblock73 is offline   Reply With Quote
Old 03-01-2009, 11:27 AM   #10
boatpuller
boatpuller's Avatar
sweet.two tone shorty.i like it.getcha a chrome rear sport bumper when you can.i think it would really help the look.sounds like a u joint or a bearing,maybe a brake hanging.jack it up and spin it.and just feel and listen,you can learn alot.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-01-2009, 01:59 PM   #11
twincam1449
No difference in temperature after a 10 mile ride.
I'll check the U joint, but wouldn't the noise be more centered?
Old 03-01-2009, 02:30 PM   #12
rick1956
rick1956's Avatar
Humming or harmonics at speed are usually u-joints or bent/unbalanced drivelines.
Bad wheel bearings usually translate into more of a roar/whine sound.
If it's a two-piece driveline it's possible someone replaced one section at some time in the past, rendering it mismatched and out of balance.
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 03-01-2009, 03:14 PM   #13
Low84
Low84's Avatar
Could it be the pinion angle perhaps? Nice truck btw, seats look good in there.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 03-01-2009, 04:55 PM   #14
84 400
Sb 400 club
84 400's Avatar
Nice truck you got there. As was said wheel bearing or u joints would be my first guess
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-01-2009, 10:22 PM   #15
silvereagle07
silvereagle07's Avatar
Put the truck on heavy duty jack stands or a lift if possible. Have someone put the truck in gear and accelerate to desired speed and listen. It sounds like a driveline virbration. Driveshaft or rearend.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-02-2009, 11:01 AM   #16
twincam1449
This morning, driving 6-7miles to work: no humm the first 6 miles, driving 30 and 50 m/h. Then suddenly decelerating a bit on the engine and the humm started again, but only for a few seconds.
Unfortunately I won't have time to check this the first two weeks.
Thanks for the replies.
Old 03-02-2009, 07:36 PM   #17
rick1956
rick1956's Avatar
Now that sounds more like a pinion bearing or a loose pinion nut...
Old 03-02-2009, 10:52 PM   #18
flamingbig10
6.0 powered square
flamingbig10's Avatar
nice truck
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
