Old 03-01-2009, 09:39 AM   #1
twincam1449
Need help identifying connector / plug
I need some help identifying this plug.
It's on a brown wire which goes into a protection tube with a lot of other wires. It's between the rear of the engine (driver side) and the firewall.
The brown wire seems to go through the firewall into the cabine.
On the plug the number 10 is printed.
twincam1449 is offline   Reply With Quote
Old 03-01-2009, 10:24 AM   #2
87Bob
Re: Need help identifying connector / plug
Check the brake circuit. I think it may go to the service brake light from the brake system under the master cylinder. What year is your truck? I'm on my way out to the pole barn I'll look at my 82 manual wire diagram and I'll let you know.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 03-01-2009, 10:46 AM   #3
twincam1449
1979
Old 03-01-2009, 11:03 AM   #4
87Bob
1979
Do you have an oil pressure gauge/light? Is it working? I can't quite see the top of mine it is burried down behind the air cleaner and the distributor. The oil inside the boot might be a clue. I looked at my 85 305 and cannot see where it might go but a 79 is older enough that they may have made many changes. I'll look the manual over for other possible suggestions. Good Luck!
Old 03-01-2009, 12:06 PM   #5
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Oil sending unit,below the distributor,behind intake manifold.can be tough to get to
powerdriver 1958 is offline   Reply With Quote
Old 03-01-2009, 01:57 PM   #6
twincam1449
Thanks guys!
This is a great forum!!
