Who's 68 SWB is this?
This is the stance I'm looking for.
I'm trying to find out drop and tire size?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
Resident of Here
Re: Who's 68 SWB is this?
Never seen it before, but the paint remind me of 67ChevyRednecks truck.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Junior Member
He posted awhile back. He had just put air bags on it with stock spindles & no Notch in the back. He said it was on bump stops all around.
Grandpa in the rustmobile...
dang i like that stance...
watcha think it'd be in....inches dropped f/r??
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Old Skool Club
![]() Join Date: Jun 2001
Static drop? I'd go with a 3.5/6. Dropped spindles plus 1-inch lower front springs up front from ECE. Out back, 6-inch shorter springs, an adjustable track bar, rear shock relocators and a replacment center cross member. ECE has it all.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
im thinkin of doing 2.5 drop spindles/5"
all id need to get would be the spindles and the springs no c notch or nothing right?, then later if i dont like the raked effect i could get 1" front springs...
Take 2 - Anybody know who's this C10 is?
I can tell you who it isn't. It isn't mine, but it is a nice truck.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Ya I remeber something like that. I saved that pic but can't remeber his name or the thread.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
![]() Join Date: Sep 2006
it's almost sitting like mine. i have a 5/7 static (3" spindle 2" spring / 5" spring 2" bock) but the tires that are on it now are pretty small. 225/70/15
![]() Last edited by ostncoln; 03-04-2009 at 11:46 PM. |
dazed and confused
i would like to know what size tire you are running.
members met: redbaron69, billsbowtie,nc67 |
Moderator
![]() Join Date: May 2007
That 68 is drop dead gorgeous whoever owns it.
#13 |
Tot Roddin'
If you're planning on running a larger dia. wheel the lowest I would go with a static drop would be 4.5/6; that will provide adequate room for turning and suspension travel.
The '68 is sick!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#14 |
the ones on it in trhat picture are 225/70/15. i have had my 85 c-10 factory wheels on the truck with 235/75/15 no problem, but with the b/s on those wheels they rub on the lower c/a more then the smoothies
#15 |
Mine is similar,
ECE 4/6 drop kit but 3 inch drop springs in front and 1 inch lowering blocks added in rear (plus C notch)... 255/275X60X15in tires |
#16 |
Thanks guys!
Maybe the owner will surface soon. From what I remember he lives out east. Just curious about more details about the rig. The C10 I'm finishing up should look pretty close.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 03-05-2009 at 12:00 PM. |
