Old 03-01-2009, 07:00 PM   #1
6packed
OL' YELLER
6packed's Avatar
Question 1967 GMC body on a 1989 GMC chassie
1967 GMC body on a 1989 GMC chassie Has anybody tried this?, Is it realalistic, My truck is a 3/4 ton Power-nothing, real low gears, top speed 60mph, I'm thinking of the switch, there both the same wheel base 131.5,
ANY THOUGHTS, thanks
6packed is offline   Reply With Quote
Old 03-01-2009, 07:38 PM   #2
fine69
fine69's Avatar
Re: 1967 GMC body on a 1989 GMC chassie
People have tried it, or at least asked about it.
TONS of work. Much easier to find 1/2 ton stuff from 67-72 to swap it over. Tons of other board members in your area who can help you out if you ask.
Do yourself a favor and become a paid subscriber. That way you can post wanted and for sale ads.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-01-2009, 08:00 PM   #3
jbristo67
resident oilfield trash
jbristo67's Avatar
What that guy said. Its only 25 a year and well worth it.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-01-2009, 09:39 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
welcome to the board.
If it is a 4X4, then it is doable. You'll have to relocate the rear axle forward since the 67 is a 127 inch wheel base, then you'll have to fab up a custom lift kit for the cab since the chassis is not flat like the 67 - 72 frames. you'll probably have to fab up mounting points for the frame and rad core support.
If it is a 2 wheel drive, don't waste your time.
If your truck tops out at 60 MPH, something else is wrong. You should be able to get it to 100 MPH.
you can convert it to 1/2 ton quite easily if that's the main goal.
Old 03-01-2009, 10:29 PM   #5
6packed
OL' YELLER
6packed's Avatar
Question Re: 1967 GMC body on a 1989 GMC chassie
Thanks for the replies,
My truck is a 1967 GMC 3/4 ton, 305 V6, 4 speed-(L,1,2,3), I need to check the gear ratio in the rearend, I guy I bought it from had it for 20years & now I'm the 3rd owner, he used it for towing his trailers, He said that the top speed is around 60 mph.
My goals are to make it go faster down the road, Put disc-brakes on the front, little body work, and replace the wood in the bed.
Any info on donor trucks to get the parts from?
Thanks, CP
Old 03-01-2009, 10:36 PM   #6
fine69
fine69's Avatar
Chevy/GMC trucks starting in 1971 had disc brakes on the front as standard equipment.
So with little effort you can bolt them in.
Find a whole 1/2 ton truck and steal the brakes and the rearend out of it for yours.
Board member #6
Old 03-01-2009, 10:38 PM   #7
Longhorn Man
i didn't think about the V6 part with it being a GMC... you should be able to get 80out of it though.
That should be a 4.10 gear in the rear with the 4 speed trans.
Old 03-01-2009, 10:45 PM   #8
CPNEJR
CPNEJR's Avatar
i would change it to a 71-72 frame so you'll have disk brakes and if you want it to go faster i would use a half ton frame for ease of finding higher gear ratios and swap the body onto that. with the half ton frame you'll probably get coil springs so it'll be a better ride.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
