Keep On Keepin' On
Lost ignition key...options??
I do not have an ignition key...What are my options?
Thanks Clint
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
Can't ReMember
Re: Lost ignition key...options??
If your door locks are the same key, remove one and take it to a locksmith and he'll make you another.
Adversity doesn't test your character; it reveals it. 71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running ![]() |
The Older Generation
I agree with what 71MUTT said. Here is a little more info on it.... Chevy Truck Lock Code Location The code number should be stamped on the door lock cylinder, sometimes one, sometimes both. The only time I have found one that didn't have the code stamped on it is when the lock had been replaced with a new one. Check the passenger door first. Generally the lock case will have to be cleaned very well to be able to see the code number. A small wire brush, steel wool, scotch bright, or sandpaper usually works well for this. I do not recommend a wire wheel because it will completely remove the code number if it is stamped lightly. The code number is always stamped into the lock case, never cast into it. Most locksmiths can cut a key from this code number. Home centers and hardware stores will not be able to do this. If the locks are original to the truck or were all replaced at the same time the key made from the code number on the door lock should fit the ignition switch. If you do not have a locksmith close to you PM me the code number from the door lock and your shipping address and I will cut a key for it for 5 bucks shipped. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-01-2009 at 08:36 PM. |
call locksmith to come to your house and make a few keys is the way i do it
![]() Join Date: Jan 2009
do a search for loc doc and read his post it is long and it is well worth it you will need all the info one day. I PROMISE you will not regret it. I read it a little while back and glad that I did. But if you want just look for code on door lock and take to lock smith for key as said in one of the previous post.
BE NICE IT PAYS IN THE END. |
have a locksmith come too your house shop or where you work at they can come too you too
Eat My Rust
Run a positive wire to the ign side of the dizzy, screwdriver to the starter.
![]() Join Date: Feb 2004
Forget the screwdriver to the starter, just ram the screwdriver in the ingition switch and turn the key, simple and easy.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#9 | |
resident oilfield trash
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#10 | |
![]() Join Date: Nov 2004
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-02-2009 at 01:49 AM. |
All of my 72s (Blazers/Longhorn/C30s) have a single key for door locks and ignition. If your door key does not work in the ignition, it most likely is the case that a PO has installed a new ignition switch/lock setup. So, your options would seem to be: 1. remove the ign switch and take it to a lock shop and get a key made., 2. have a locksmith come to your truck and do the same thing, 3. buy a new ignition switch lock, with key. Otherwise, you could eliminate the ignition switch, seperately wire/switch all of the functions now controlled by the ign switch, and you are on your way. Come to think of it, it could be cool to have just a turn key "on" and a push button starter control - like my Dad's old 49 Chev Fleetline.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
vin + insurance papers + id
If its an original ignition dealership might be able to help. Go talk to them. |
#13 |
go to autozone and get a new switch they are like $20 here...
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#14 | |
![]() Join Date: Jan 2008
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
#15 | |
LockDoc
